MASantos
- Dec 21, 2004
So I came up with this crazy idea of designing a power supply for my PINT. At the moment I am starting to learn how to use Eagle and I believe that this will be a nice first project that will give me enough experience to do an amp afterwards.
My self imposed requirements are the following:
Transformer will be an Amveco 62010, which fits the case perfectly. It has a diameter of 42mm which leaves a PCB area of 38x45mm(LxW). This board area must include the IEC and either a DC jack or strain relief. Qualtec 771W-X2/01 looks like a good choice but I would prefer something less bulky (I know this will be hard to find).
For the filter cap I have two choices depending on board space:
I am trying to fit 2x the 680uf ones.
So here are the questions:
Diode bridge: What should the minimum specs be? Acording to the specs of the transformer, I shouldn't need more than 50v and 0.5A right? I have found these ones:
MB2S DF04M HD02
Would the SOIC be a good option or should I go the one with higher values to be on the safe side?
Regarding the bipass caps, Tangent says:"The exact value to use here is not terribly critical. 100 pF is a reasonable value. If you choose a different value, I'd say smaller is better." How low can I go and are there any benefits in doing this?
Regulator: I will probably use a LM317( Other options?). Is there any reason why I shouldn't use the SOT-223 package? They are rated at 1A and this circuit won't draw more 0.2A so there shouldn't be any problems right?
Resistors, protections diodes,LED:
SMD's all over.
Resistors are 1206, Diodes are S1A, Led is a through hole 3mm. (I'm still not sure if the Front panel will have a led, but it is always good to have one, even if only to discharge the filter caps)
Bipass Cap: any reason not to go SMD with this one?
Output cap: In the LM317 datasheet refers to a tantalum or electrolitic for this position but doesn't say which is better. I haven't found anything in tangent's pages.
All opinions are welcomed!
Manuel
- MUST fit a Hammond 1455C801 enclosure.
- Output:12-14V and at least 150mA of output current.
- Should perform as good as, or better than a TREAD.
- Panasonic FC 680uF 35v, dimensions:16x15mm(DxL)
- Panasonic FC 820uF 35v, dimensions:18x15mm(DxL)
MB2S DF04M HD02
SMD's all over.
Manuel
