Dongle
- May 4, 2013
Here's my supplemental review to the main reviewer:
The "bass slider" has 8 dots on it for visual reference. For me, the sweet spot is dot 5 or 6.
Despite housing a AA battery in one of the ear cups, it's surprisingly lightweight. However, if your hair is long (mine is) the headband tends to pull out hairs. The part that allows the earcups to swivel is the culprit.
The headphones I've compared these against are the Grado SR80 and Sol Republic Tracks. Both those headphones handle mids and highs better and have wider soundstages. I can't say that the 40mm drivers are terrible, but they're flat. However, the Sensation 55 drivers are AMAZING. They really nailed it.
Although you can feel some vibration in the headband and ear cups, it's very minor. I could wear these for hours without it giving me a headache or giving my skin a tingling sensation. What the vibration does do is translate into that low, deep rumble that you feel in movie theaters. When the bass slider is too high or two low, it's as if the "sub" is out of sync with the speakers. But if you can hit it just right (for me it's setting 5-6) then it tunes well and sounds like a home theater. I pulled up a Man of Steel trailer on YouTube and no headphone has ever hit those deep low's that a real home theater sub can hit.
What strange is that, in every other headphone, to get the bass to hit this hard you have to jack up the volume in a way that likely damages your ears. These headphones give you heavy bass at low volume. It tricks you into thinking you're listing to music far louder than you actually are. You pull off the headphones expecting some fatigue, but there is none. That's a brand new listening sensation.
I wish the 40mm drivers, not the "subs" (Sensation 55 drivers) weren't so flat. If Skullcandy releases a Pro or HD version of these with cleaned up mids/highs and makes the design less angular as to not pull out my hair, they will have made my favorite headphone. I hope every manufacturer starts incorporating dedicated "subs" into their headphones. It's sort of crazy that it took a company like Skullcandy to figure this out (no offense, but they don't have the reputation of Sennheiser or Shure).
As it stands, I will be returning these. I want to like them so much and make them my one go-to headphone, but the rest of the sound rage outside of the bass is just too lacking for me and I'm not so well off that $100 is trivial.
