Singxer SU-6
post-15604141
Post #286 of 324
cglin222
SU6 I2S will give your DAC 3 clocks, your DAC will only use 2 of the 3 (bclk,lrclk).
You mentioned that there was no option to select and use external clock on the D90, you might want to check with Topping if this is true
So they replied me that d90 can't use external clock
So goes back to my question if the i2s have all 3 clk pins +/- why I can only get the bclk and lrclk from su-6? And not the mclk? I2s have pins for that and if su6 is sending it?
post-15604146
Post #287 of 324
cglin222
D90 don't have a clock port in therefore it can't
But from su-6 I don't see why if it's passing in all 3 and i2s have all 3 pins for it?
post-15604157
Post #288 of 324
b0bb
SU6 is sending MCLK to your DAC
D90 DAC is not using the MCLK signal from I2S, from your message about Topping's reply
Reactions: Baten
post-15604161
Post #289 of 324
b0bb
You have to ask Topping why they have a I2S MCLK input pin but not using it.
(Or ask them if D90 can use I2S MCLK and tell them you have a SU6)
post-15607788
Post #293 of 324
Roasty
does it make sense to use the SU-6 with an SOtM SMS-200Ultra which has the sCLK-EX clock?
post-15609287
Post #294 of 324
b0bb
I have that combo, the SMS-200 is underpowered for DSD512 and above when running HQPLayer's NAA, it starts to pop and click.
No problems on Roon@DSD512.
Reactions: Baten and Roasty
post-15609291
Post #295 of 324
Roasty
Thanks so much for that input!
post-15609672
Post #296 of 324
DecentLevi
Seattle area
Seattle area
Hey guys remember a few days ago I posted the USB input of my SU-1 crapped out? Well low & behold it's WORKING again today after just upgrading the driver. It's so strange because although nothing was changed on my setup, one day when powering everything on my PC stopped recognizing the SU-1 and even the left light of my Wyrd kept going out after 5 seconds as if there's no connectivity. And what a relief because my SU-1 is serial SU-000263 all the way from late 2016 and both Kitsune Hifi and Shenzhen Audio seemed reluctant to still service it.
I updated to driver 4.45 but someone at Kitsune Hifi recommended version 4.80, but I can't find the link. Is there any advantage of the latter version or should I just stick with this one since it's working?
Also he recommended I update the firmware. I don't believe I've ever upgraded that since (perhaps?) after getting it almost 4 years ago. Any recommendations on which firmware version is better, or if it makes any difference?
So for anyone who thinks their SU-1 is broken one day but the power light still comes on, consider updating the driver.
Reactions: motberg
post-15609685
Post #297 of 324
Baten
That's all very odd :D but good it still works.
post-15609751
Post #298 of 324
cglin222
Maybe this driver page will help
http://www.singxer.com/col.jsp?id=108
Reactions: Baten
post-15609760
Post #299 of 324
DecentLevi
Seattle area
Seattle area
Yeah I was convinced it was a hardware issue and was even talking about having the board replaced, but the driver update fixed it. Somehow it slipped through the cracks that these things even need driver updates - was under the impression just keep the firmware / driver so long as it works. And thanks for the above link, I was using the one from Shenzhen Audio which isn't as up to date. Which firmware is more up to date from the above site, the 2017 one or just the "firmware update"?
Probably I'll be going with a DDC that supports Toslink optical for my next upgrade, because I've heard that's the superior connection type - that and HDMI.
