Definitely agree about your compliment to @Energy. As for the mod, I haven't done it to my KTE.Yep. Tell me about it. Quite amazing for @Energy given his very young age compared to some of us around these forums. I guess some people are just nice, like to help the other, and passionate in a non-selfish way for this hobby.
Definitely a NOT subtle improvement on SQ, and I am not even expert on this to easy tell. Easy, non-expensive mod too, especially if you have a LPS-1 laying around
Singxer SU-1 Owners
- Thread starter T Bone
thyname
Oh man, KTE version of SU-1 plus LPS-1 as power supply should be awesome! I think changing the power supply was the only thing Tim left out from his KTE mod of the SU-1, but I may be wrong
You're correct, the PS is the same.Oh man, KTE version of SU-1 plus LPS-1 as power supply should be awesome! I think changing the power supply was the only thing Tim left out from his KTE mod of the SU-1, but I may be wrong
I'm considering doing the mod.
captblaze
the stock power supply gets some work also. The quote below is taken from the KTE-SU1 product page
"Singxer KTE SU-1 – KitsuneTuned Edition w/ upgraded FineGold Caps, Wima Film caps and ultra high performance discrete regulator – 3.2uV output noise, 125db PSRR (power supply rejection ratio) compared to the stock regulator @ 150uV output noise and 70db PSRR approx."
Yes, but it's the same PS that is in the SU-1.the stock power supply gets some work also. The quote below is taken from the KTE-SU1 product page
captblaze
I suggest you contact Tim at Kitsune and ask him directly what he has done. I had a pretty extensive conversation with him prior to purchasing a KTE-SU1 for myself.
I also had an extensive conversation with Tim prior to purchasing the KTE SU-1 (especially since I owned the SU-1) and I understand what he did to enhance the performance of the PS. My point is it's still the same PS itself.I suggest you contact Tim at Kitsune and ask him directly what he has done. I had a pretty extensive conversation with him prior to purchasing a KTE-SU1 for myself.
Thenewguy007
- Jun 22, 2013
What AES cable are you using? Looks nice.
rafabro
- Oct 28, 2016
When you replace 90% components it is no longer same device. PCB can't "create" the sound and also doesn't matter if looks similar.Yes, but it's the same PS that is in the SU-1.
Geez, my point was the PS wasn't replaced! And I never said it was the same device.When you replace 90% components it is no longer same device. PCB can't "create" the sound and also doesn't matter if looks similar.
I know what was replaced, it was explained to me by Tim at the time of purchase and also the reasons why.
rafabro
- Oct 28, 2016
Thanks for the link.Found a link for the new firmware from another local for others that bought there one somewhere else.
https://download.shenzhenaudio.com/Singxer/SU-1-Firmware-2017.rar
No problem to update firmware 2.02 -> 2.22, now would be great if we have driver capable to handle nonDoP . 3.34 can't do it.
EDIT
Holo Audio driver 3.40 does the job as someone said before. Native DSD512 with my Gustard - no problem.
Thanks. I bought a WireWorld Starlight Gold cable. I wanted to see how a top-of-the-line AES cable would compare to I2S.What AES cable are you using? Looks nice.
AES performed admirably, but I2S had the edge. The difference isn't the cable - it's the fact that AES signals go through a "receiver" chip. I2S signals don't go through a receiver chipset, they more or less go straight into the R2R network.
P.S. This AES cable is available - PM me for a sweet deal!
drkingweeb
- Jan 27, 2012
hello,Sorry. I should have been more clear. Uptone Ultracaps LPS-1
is there a part # for the small connector that the dc wires plug into that connects to the main pc board?
thanks, drmike
Thenewguy007
- Jun 22, 2013
Got my DC power conversion kit upgrade.
Now the question is which Linear Power Supply to get?
I don't want to get the cheapest one that will barely be an improvement, but the prices on LPS skyrocket when you go to the bigger ones.
Any good ones in the $500 range?
Some of the ones I looked into:
Paul Hynes Design SR3
Qualiaphysic 271 SV
Plixir Power
Teralink LPS
Channel Islands MKII
Uptone JS-2.
Wyred 4 Sound PS-1
HDPLEX 200W
Qualiaphysic 271 SV
Plixir Power
Teralink LPS
Uptone JS-2.
Wyred 4 Sound PS-1
HDPLEX 200W
thyname
Qualiaphysic 271 SV
Plixir Power
Teralink LPS
Uptone JS-2.
Wyred 4 Sound PS-1
HDPLEX 200W
Ultracaps LPS-1 by Uptone
