sacd lover
- Aug 31, 2002
I would start by just replacing the gain tube with a 6gu7. However, if you use high impedence headphones like the senn 580/600/650 .... using the 6gu7's as output tubes will give you plenty of power. The tube only costs $5-6 so buying three and experimenting would be a potentially high reward low loss proposition.
Originally Posted by sberger would you recommend replacing all 6cg7's with 6gu7's, or just the input or output tubes? |
