whill
- Mar 10, 2016
Hi!
To answer your question, it depends on your taste. I was in the same situation as yours when i was looking for a headphones to replace my 940 which has build quality issues. However, i ended up buying the Shure 1840 which i still have (2nd headphone). If i am to be asked about the difference of 1840 to 940, to my ears the 1840 is sounding a bit forward, while 940 a bit bright and i suspect that the 1540 will be a bit warm. You cannot go wrong with the 1840 as long as you dont have a system that will sounds forward for it will make the overall sound "shouty".
Let me know if you need to clarify something.
Sent from my iPhone using Tapatalk
