AgentXXL
- May 11, 2008
You will get the refund fast. I got mine the next day. I would not buy another set. Yes you get to keep that one whenever it manages to reach you and maybe you will be happy with them or they release a firmware update to fix some issues. I am really happy with the $24 set. The battery life and range is good. You just need to buy 2 pin to MMCX adapters but the wings are soft and flexible which would be perfect for you to sleep with. The Fiios aren't worth $150. IF you are going to spend that I would just get another TW2 set so you always have one charged. 4 hour battery life is rubbish. I get 6 with the $24 set.
To be fair, that 4 hr battery life has shown to be a defective. Others are reporting 6 - 8 hrs depending on the attached IEMs and volume level. I'm more concerned with the issue that the earhooks don't charge if the door of the case is slightly open. That I can 100% agree on as something they need to fix. As for the app differences, hands-down the Shure Play app wins.
I haven't used the environment mode on the TW2 enough to judge its quality when compared with the Transparency mode on the AirPod Pro 2nd gen, which so far I find performs better than anything else I've tried. The ease of use of their adaptive mode and the fact that they seem to drain fairly evenly is a win for them, compared with the TW2 on which the active earbud drains considerably faster. That to me is a big fail on Shure's part - it should automatically switch the active one between earbuds to keep them draining evenly. And literally all of us would agree that they should design these BT adapters with changeable ends so you can use MMCX or 2 pin or whatever comes down the road.
Based on similar features from other products, Apple has done an impressive job with the capabilities of the AirPod Pro 2nd gen. Certainly they don't sound as good as the SE846, but that can change with future models. And really, I just want decent quality when mobile - very few of us would use Bluetooth for critical listening. My use case is even more specific, as I really like having my mobility to do things around the house while listening, but have grown to love watching movies, TV, YouTube, etc using IEMs or headphones.
I likely won't purchase the UTWS5 2025 but hope that it does get delivered once the strike is settled. Instead I'll keep watching for a decent deal on a pair of BT capable fullsize cans. The contenders so far are the Bose Quiet Comfort Ultra, the Sony WH-1000XM4 and the Apple AirPods Max. Hard to justify the ~$200 CAD price difference between the the AirPods Max and the Bose QC Ultra. And the Sony XM4 are even ~$200 cheaper than the Bose QC Ultra. Sony $278 vs Bose $469 vs Apple $647 (all in CAD) with the post Black Friday/Cyber Monday sales that run until end of the week.
