Shure SE846 Impressions Thread
Nov 15, 2019 at 8:07 AM Post #20,446 of 22,942
i have two sets of the Shure SE846, never had any problems, did change the cables tho, the originals are pretty bad and when is cold outside they get pretty hard. i had the chance to listen to the new Campfire andromeda and i tell you i was really impressed, my audio source was my Astell & Kern SR 15, after one hour of testing i was sold, so the Andromeda will be my next purchase, they do have a wider sound stage with a real Punch.
I also have 2 sets of the 846 with original cables and have never had any problems other than discoloration due to copper oxidation which doesn't affect the sound. I too have the andromeda and find it very impressive though it doesn't have 846 bass. The 846 has always been my ultimate go-to. I think you can't go wrong trying again.
To OP : I know you said you're not interested in more expensive CA iems, but I just recently got hold of the Solaris, and the sound is amazing. Imagine an 846 with dynamic driver bass, solid mids, and holographic highs. Because of the size, I can't use it, though, where I might use the 846, (say, going to sleep).
Nov 15, 2019 at 8:08 AM Post #20,447 of 22,942
I replaced cables on the replacement pair and the same thing happened.
Going back on my statement about not being interested in campfire. Looking at the Atlas, Solaris and Andromeda. Don't really care on the price, just want the best ones.
Nov 15, 2019 at 8:28 AM Post #20,448 of 22,942
I had the Atlas and to my ears they're not better than my 846's and of course that just my opinion. The Atlas is somewhat bright and there's this persistent problem with flex using silicone tips. As matter of fact I ship the Atlas out today due to me selling them on eBay and I'm not gonna look back! See ya! I guess the grass ain't necessarily greener on the other side.
Almost sold the Shures without first listening to the Atlas and that would have been a huge mistake! The Andromedas are a different story though. I love them for their midrange/treble and coherence. To me they're holographic. The bass is okay but if I desire a good rumble the SE846 is on standby but they play well with any genre. Haven't heard the Solaris.
Nov 15, 2019 at 11:44 AM Post #20,449 of 22,942
I had 846s for a couple of years but I have constant problems with them. I had them replaced once through warranty, but the same thing happened again once warranty was over. The cables become jammed into the earphones and can't be removed without destroying them. I also got regular distortion in the first set, probably caused by the cable problems.
I've had Shures for years, starting with the 530s in around 2008, then the 535s, then the 846s. Generally the build quality has been good but my experience with the 846s is making me think again.
Shure have offered my a brand new pair of 846s at a discounted price so I'm wondering whether to go with that, and hope this time they last more than 2 years. But are there any other options out there at a similar price people can recommend? I'm currently using Campfire Audio Comets because they're 'cheap', and they're ok - but honestly nothing compared to my 846s. I'm not interested in any of the more expensive Campfire Audio options either.
By the way, I really looked after my 846s. I commute / take a lot of flights, but I didn't do a single thing that would have contributed to their damage, so 'being more careful next time' isn't gonna help me.
Personally I don't have any problems with my pair, except for a broken cable (needs to be replaced anyway for maximum listening pleasure [transparency!], let's say by an ALO Reference 8 or a FiiO LC-3.5D). I still like it quite a bit, but meanwhile prefer Atlas, Andromeda and FiiO FH7. Atlas and FH7 are my favorites and probably endgame, if nothing revolutionary shows up in the future. Note that I equalize all my ear- and headphones to a perceivedly even frequency response, so my ratings are to be considered under this aspect. The SE846 sounds best with an empty filter tube and a relatively massive EQ compensation for the resulting treble excess – and with foam tips for minimized inner reflections = maximum transient accuracy. This way it has a surprisingly convincing treble extension, unlike its reputation.
This response has forced me to audition the SE846 again since a while, and I'm surprised how good it sounds even compared to the two newer IEMs. However, I like the other two a bit better: the Atlas for its soundstage, clarity, neutrality and punch, the FH7 for its warmth, organicalness, incisiveness and authority – it has the blackest, most impressive bass of the bunch (thanks to the huge beryllium-plated dome membrane).
If you decide to stick with the SE846 (not a bad decision by all means), try my modification and most notably allow it a better cable, let's say the FiiO LC-3.5D!
Nov 15, 2019 at 12:02 PM Post #20,450 of 22,942
Without knowing how you attempted to separate the connectors, I cannot understand "jammed into". Please define what you mean by that.
They ARE tight fits. But it is easy to separate them if you take half of the connector in each hand and insert the fingernails of your left and right-hand index finger and thumb simultaneously into the space between the halves. Then as you press the tips of the nails in together toward each other, the two halves pop apart with no pulling or prying whatsoever. Pulling them apart by any other means is very hard to do.
I hope that was the case here, that you were simply using the wrong technique to get them apart, and that trying this method I describe brings you success.
Terry
Nov 15, 2019 at 12:27 PM Post #20,451 of 22,942
I have had almost every Shure SE series and have no problem with their connection. I took a break after the SE535 and went with the fiio line up, but now returning to the Se846, This time i just leave every cable in the box and plug a balanced braided copper cable.
also im using every day in my commute, but at work or home, i always leave them in a sealled box with silica bags for any possible moisture.
Duno if there is some external factor like rust forming in the connectors. Sad to hear that happening.
Nov 16, 2019 at 5:35 AM Post #20,452 of 22,942
Have no problems with the stock cable connection or removal on the 846. Once I tried a third party cable which was too tight but still removable after some elbow grease.
Compared to Andromeda, I still prefer the more balanced sound of the 846. I don’t like the Andromeda’s hard bass, recessed mid and overly boosted high. Also, the 846’s fit, comfort and isolation is very good, one of the best from any iems I have tried.
Nov 16, 2019 at 7:42 AM Post #20,453 of 22,942
I am leaning towards new 846s as I know what I'm gonna get. I could spend twice as much on the Solaris but my instinct tells me it won't be worth it and it's too risky, moving from a "shure" thing LOL
On the cable queries, 100% defective, proven by the fact that when returned to Shure they agreed replacement and didn't just return them back with a message on how to remove them. There's a video on youtube on "how to remove shure cables" and quite a few comments by people there on having the same issue, that after a year or two, it became impossible to remove the cables without using dental floss. Not exactly ideal for a product offering 'removable' cables. And the only thing making me hold back on my decision. Knowing my luck, it is a 2 year investment because I think the same will happen again, and after that time Shure could not care less. So is the £££ / 2 years really worth it. Hmm..
Nov 16, 2019 at 2:42 PM Post #20,454 of 22,942
I have both the SE846 and the Solaris and I've sold off all my other IEMs and kept these two for specific reasons. The Solaris definitely has a leg up in terms of sound quality with more defined and punchy base, holographic high-end, and a soundstage that is really incredible for an IEM. The Solaris out of the ES100 seriously competes with my desktop rig. The SE846 is close, but the main reason it ends up getting more use than the Solaris is comfort and portability. It is hands down the most comfortable IEM I've ever tried and I don't think twice about throwing in my pocket, where as I feel I need to baby the Solaris. I usually pair the SE846 with the BT2 bluetooth cable, and I think this combo is unbeatable in terms of sound quality to convenience/portability factor, though the SE846 does improve noticeably from a better source.
Nov 16, 2019 at 3:10 PM Post #20,455 of 22,942
Good info thanks. Based on that, as nice as it would be to try the Solaris. gonna get 846s again.
Does anyone know how many cables the 846 BT2 package comes with? I'm not interested in Bluetooth really, but I hope it still comes with 2 standard cables?
And does anyone have any non-shure cable recommendations? I fancy a good cable and keeping the shure cables as back ups. I previously had the Linum G2 BaX cable but it disintegrated after about 2 months, the cable was so thin and fragile. Nice sound quality though.
Nov 16, 2019 at 3:43 PM Post #20,456 of 22,942
Nov 16, 2019 at 5:10 PM Post #20,457 of 22,942
Mine came with two cables but both were the same which I didn’t understand.
On another note, I almost sold off my 846 and thrilled that I didn’t. It’s really an awesome IEM.
Nov 16, 2019 at 7:17 PM Post #20,458 of 22,942
Came with 3 cables, the standard 3.5, a 3.5 with mic and the BT1. Never used them btw
Nov 17, 2019 at 2:10 AM Post #20,459 of 22,942
Nov 17, 2019 at 2:17 AM Post #20,460 of 22,942
I have both, they are pretty light and
They are
Copper Litz cables with A WIDER SOUND STAGE WITH A REAL PUNCH
