Shure SE846 Impressions Thread
Mar 6, 2018 at 11:00 AM Post #18,751 of 22,942
Are there also reported fake shure ios cable? This is what it came with.
I haven’t seen a fake Shure iOS cable - as Lightning would either work or not, in my opinion.
Mar 6, 2018 at 11:01 AM Post #18,752 of 22,942
Mar 6, 2018 at 11:02 AM Post #18,753 of 22,942
All the buttons are working perfectly fine on my iphone. Have not tried the mic yet though.
Mar 6, 2018 at 11:04 AM Post #18,754 of 22,942
I’m going to assume the mic works, especially since you aren’t receiving Lightning incompatibility messages whilst plugging into your iDevice.
Mar 6, 2018 at 11:10 AM Post #18,755 of 22,942
Hopefully yes. But can anyone from here share the quality of sound of A fake one? Or has anyone experience it before?
I just love the bass and mids on this thing. I woudn't think this is fake unless I do a side by side with another legit 846 with the same set up then they sounded differently.
Mar 6, 2018 at 11:16 AM Post #18,756 of 22,942
I’m not sure of anyone who owns a fake Shure iOS cable, as a fake would more than likely not be MFI certified, which would/should immediately give you incompatibility messages when plugging the cable into an iDevice.
I would compare and use the same color filters that are in the legit SE846 with the new/used Blue SE846 and critically comparatively listen.
Mar 6, 2018 at 11:36 AM Post #18,757 of 22,942
https://www.head-fi.org/threads/counterfeit-shure-se846-dissected.823376/
I was checking this thread before buying them. The metal sound tube looks different so that's one relief for me.
The sound description as well from the ts made reference that the fake 846 he got has no bass. This is a 2nd relief for me.
But that thread was in 2016 so there could be changes now on how they fake the 846.
I just hope to do a comparo asap to confirm whether my unit is legit or not.
Mar 6, 2018 at 11:38 AM Post #18,758 of 22,942
Mar 6, 2018 at 12:16 PM Post #18,759 of 22,942
Something about your blue SE846’s look off. For one I don’t see the name or the model number on them. Then the color is not matching the color in the photo. Take a look at the picture below:
Mar 6, 2018 at 1:07 PM Post #18,761 of 22,942
Hello,
your SE846 seems to be real : looking at tubes or engraving, but you will have to make some more tests like unmounting tubes in order to extract acoustics filters and see the inside of the Shure.
Mar 6, 2018 at 4:55 PM Post #18,763 of 22,942
After a closer look, I do see the Shure logo. So yeah they do look real and like a legit pair. You got a bargain my friend :ok_hand:
Mar 6, 2018 at 5:59 PM Post #18,765 of 22,942
For some reason it looks a bit violet in the picture but it is blue in person. It also has the shure logo on the faceplate while the se846 marking (L and R) at the back plate if that's the right term for it.
