Shure SE846 Impressions Thread
post-13497997
Post #17,911 of 21,114
Arghavan
try changing the cable
the two included cables didn't make a difference maybe I should try an aftermarket cable
Also try gently cleaning the MMXC connection. Check the female connection inside the earphones for breakage. When I clean mine, the pointy little alcohol soaked cotton swab came out black
Thanks I will try that
post-13498000
Post #17,912 of 21,114
Quadfather
Illinois
Illinois
Be very careful, there may even be kits out there specifically designed for cleaning mmxc connectors.
Reactions: Arghavan
post-13498020
Post #17,913 of 21,114
Sound Eq
i suffer from hearing loss in left ear did u do a hearing test as with iems that gets magnified more than headphones, so i have to manually adjust balance setting in a dap
post-13498065
Post #17,914 of 21,114
Arghavan
when I put in earphones reversely the right side will be louder instead.
post-13498092
Post #17,915 of 21,114
Sound Eq
post-13498742
Post #17,917 of 21,114
tbritton
Elizabeth City, NC
Elizabeth City, NC
Age
68
Website
terrybritton.com
Hey, folks - you likely won't believe this, but I have not owned a cell phone in over ten years (not since my Cingular 8125/HTC Wizard). But I am finally getting one, via Verizon this time as they have the best coverage in my region of the world.
So, with the SE846 preferring 9 ohms impedance or below, what choices do I have (besides iPhone, which I've heard sounds great with both the 6s and current 7 models)?
Recent arrivals are the Moto-Z, the Samsung S8's, the LG V20, and the LG G6. The Samsung S7 is now pretty cheap, but I never heard any raves about that unit, audio-wise.
I was interested in the Google Pixel until I read it had a 16-ohm output impedance. Too bad!
Any impressions from folks successfully using their SE846's with their phone? (No outboard DACs or Amps involved... have to travel light with this.)
Thanks for the input!
Terry
post-13498756
Post #17,918 of 21,114
joshnor713
Seattle Area
Seattle Area
Terry
The V20 (or LG G6 if you can get the variant with the Quad DAC) is your best bet. I've had the S7 Edge, V20, G6, and currently the S8+. LG's Quad DAC easily sounds the best. To me, it's equivalent to an entry-level DAC (~ $200).
The S8 is noticeably better than the S7 (I hear no hiss at all), but the SQ pales in comparison to the Quad DAC. Still, it's better than the LG G6 without the Quad DAC.
Unfortunately, regarding output impedance, we're never given what they are on phones. So no one can say which technically pairs better than the 9 ohm SE846.
Hope this helps.
post-13498810
Post #17,919 of 21,114
Sound Eq
Terry
i have lg v20 and iphone 7 plus 256 gigs and the iphone sound way better with my shure
Reactions: tbritton
post-13499454
Post #17,920 of 21,114
tbritton
Elizabeth City, NC
Elizabeth City, NC
Age
68
Website
terrybritton.com
Yes, that little dongle/DAC on the iPhone appears to be a great item, as it turned out!
The MOTO-Z (and Z-Force) have that USB-C-to-headphone jack thing that I imagine is a similar DAC in a dongle. I haven't heard anyone talk about its sound quality, though.
Terry
post-13499531
Post #17,921 of 21,114
joshnor713
Seattle Area
Seattle Area
I tried it, it's not good.
Reactions: tbritton
post-13504011
Post #17,922 of 21,114
ThomasHK
removed
post-13504147
Post #17,923 of 21,114
AviP
Alright guys, now that I have the lab up and running, time to share some measurements with you guys. First set of measurements today is on the different eartips and their influence. Later I'll share measurements on the different filter mods. Probably some time next week. Let me know what else you would like to see.
NOTES:
  • equipment: G.R.A.S. KEMAR with antropomorphic ears (i.e. with real ear canal), Audio Precision APx525.
  • All measured at characteristic voltage (--> 500Hz = 94dB)
  • Used my filter mod for these measurements (= white filter with one foam)
My Buddy
Different tip measurements
[ATTACH1]2328824[/ATTACH1]
measurement comments:
  • best extension found with SpinFit (as reported by many), worst extension with Shure silicon tips (no surprise given the narrow diameter)
  • Smoothest response = Shure Olive --> interestingly seems to dampen some of the low mid resonances, cool!
  • Comply Ts500 also has smoothing characteristics in low mids, but worse extension than Olive.
  • I wouldn't pay too much attention to the very low frequencies roll-off exact values, but in general the foam tips will have a natural high pass filter effect (not perfectly sealing)
L/R Balance
[ATTACH1]2328825[/ATTACH1]
The sad side of having measurement equipment... finding issues with your gear. My right side sample has 2-2.5 dB higher sensitivity in the mids. It's not a big issue as I'm actually slightly less sensitive on that side :D
Harman curve compensated responses
[ATTACH1]2328826[/ATTACH1]
Note:
graph says SpinFit, but it was actually with the Olive tip.
This to me shows the real value of the SE846. Properly balanced response! There are not a lot of multi-BA earphones which such a balanced response. Closest I've seen (or even better) is Prophile 8.
Yes, the top octave is rolled off too much, but I don't think that's a big issue.
More easy to interpret graph below, normalized to 630Hz +/-10dB.
[ATTACH1]2328827[/ATTACH1]
Once more the Shure SE846 with white filter foam mod and Olive tips (smoooooth :) ).
[ATTACH1]2328828[/ATTACH1]
What is the white filter foam mod?
I'd be curious to see measurements with the Comply P-series tips, if you have a chance.
Also, a comparison of the 3 original filters.
Also, if you have SE215, I wouldn't mind seeing a comparison.
Thanks! :ksc75smile:
post-13504184
Post #17,924 of 21,114
ThomasHK
White filter mod = white filter + one piece of foam from the blue filter. After many back and forths it's the one I settled on. I will measure the different filters and mods next.
No P-series comply or SE215 around, sorry.
Users Who Are Viewing This Thread (Users: 1, Guests: 8)
