Shure SE535 - clicking sound with a cable ??? :/
Dec 11, 2013 at 2:08 PM Thread Starter Post #1 of 9
lukair
Hey guys
I just bought a SE535, which are fantastic, musically, and first set of earphones with such quality. However...
Does any of you, who also own the same earphones, encountered this? Turn the volume to the max, and listen...
http://dl.dropbox.com/u/23242740/20131210_142839.mp4
Dec 11, 2013 at 2:40 PM Post #3 of 9
Thanks Mooses
I bought them new, from official distributor. I just contacted them, but I also wanted to inquire within the community to see what you guys would say about it, and if "those earphones just have it". It is incredibly annoying, since when you wear them, and the cable often gets lightly, or more forcefully pulled, this sound "ressonates" to the inside of an ear, and you hear it loudly while listening to the music (again, very irritating :/).
Dec 11, 2013 at 2:45 PM Post #4 of 9
well since you bought them new, i doubt its snapped probably just a internal issue, i hear you though, when you spend good money you dont feel like dealing with BS like that even though its minor
Dec 12, 2013 at 11:07 AM Post #7 of 9
Ok guys, I have conflicting report here. I contacted shure.de, which engineers apparently claim "this is normal behaviour", however believable it is (???), while shure US said, the earphones should not produce any sound whatsoever, aside from the music itself.
I also make it hard to believe that, as those engineers claim "this is a normal behavior for this part of the cable as it is not supposed to be moved but safely rest behind the ears". The reason I find it hard to believe is that a 6x cheaper set of shure I owned for 2 years prior (Shure SE215) did not have this problem at all. Secondly, I do nothing extreme with these earphones. In fact I'm pretty pedantic person, and I care a lot about things I buy. If I wear earphones, I move my head 30 degrees to the left, and right back and forth, and I hear "clicking sound" everytime I do it, surely this is not normal for 500$+ earphones, right?
Please guys, confirm, that your set of shure se535 does not present such a behaviour.
