jamington2004
- Feb 23, 2015
Almost perfect with the Qudelix 5k in tow! But the leather pouch has a curve on it and the 3M sticky backing isn’t strong enough to stop it flattening out on the sides! Will work out how to perfect it - with gorilla glue if needed!
The hole in the bottom is to force the amp out with a plastic chop stick as the leather case is so tight fitting
