I just got the KSE1500 yestersay. Curious do you all hear popping sound once in a while with usb connection from Iphone 7? I hear alot of popping sound.. strange when I pause it, I did not hear popping sound.. only when music is playing.
Shure KSE1500 Review - Shure KSE1500 Sound Isolating Electrostatic Earphones
- Thread starter jude
Ok solved popping sound with Iphone 7. This is what i did//
1)Unlock your iPhone
2)Hit settings
3)Tap General
4)Scroll down to reset
5)Punch "Erase network settings"
6)Wait for the phone to reboot and recommence initialisation
There was a known bug with Iphone 7 using external dac connected directly to it. The noise cancellation is causing the popping sound. Either reset the network settings or turn off noise cancellation works.
I would like to thank myself so much for the tips. Audiowood is such a cute and sweet person..
2)Hit settings
3)Tap General
Mimouille
@Audiowood, cool so how do you like them so far?
spook76
- Jan 13, 2013
2)Hit settings
3)Tap General
I would like to thank myself so much for the tips. Audiowood is such a cute and sweet person..![]()
I have heard the same about Audiowood
One tip give NePLAYER app a chance as your player of choice on your iPhone. I have bought and compared all of the apps that allow you to play high resolution music and on pure sound quality I found NePLAYER the best. I would also recommend Kaisertone if the user interface is more to your liking.
After listening for 10hrs, I kind of felt a sense of great regret..
I should have gotten this earlier... it's technically on another plane of existence above all other. Sound so good I have literally no words.. only silence for 10hrs...
I have heard the same about Audiowood.
Ok I will download and try the ne player.. thanks a lot.
Mimouille
Yes they are, but others are a good complement because sometimes you want another flavor...less transparencyAfter listening for 10hrs, I kind of felt a sense of great regret..
felixaaron
- Apr 14, 2015
Just a heads up... I'm not in the market, but I saw Shure KSE1500 for $2500 on buysonic.com. I bought my Westone W40 there in the past for a deep discount. Authentic product with quick shipping.
No KNOTsense
- Jun 15, 2015
Do any of you guys have a problem where the lemo connector is loose to the point where the iems can disconnect with slight pressure on the plug?
Mimouille
No.Do any of you guys have a problem where the lemo connector is loose to the point where the iems can disconnect with slight pressure on the plug?
Danz03
- Aug 8, 2010
Neither for mine too
Eroica4th
Banned: Multiple incomplete trades. Previously known as Exhuman93
- Jan 8, 2015
That is dangerous. You should stop using it since it is instructed that you insert the lemo connector first then switch on the amp/dac.
Whatever is happening to ur lemo connector only shure can fix it. Remember it is a high voltage and risks aren't diminshionless in here.
Jwm48324
- Sep 21, 2010
Anyone have customs made by the recommended Shure company and if so how do they compare to the stock squishys?
spook76
- Jan 13, 2013
Yes, I use the Sensaphonic custom sleeves (SCS) with my KSE1500s. I thought I had a good seal with the Westone Star Tips or the Shure foam but unlike my SE846s, one ear was a little uncomfortable for extended listening which led me to Sensaphonics. Also, when I was in Chicago fellow Head-Fi member MCoupe threatened me with unlimited Taylor Swift listening if I did not go over to Sensaphonics office which was less then an mile away.
I preface my reaction to the effects on the sounds with the caveat that insertion depth, anatomy of an individual's inner ear and proper fit of the custom sleeves have a large effect on the acoustics. That being said, I found the comfort and tonal changes very striking. I expected because of the perfect seal an increase in the bass response but what surprised me was an equal increase in the treble response as well with no diminution of the midrange.
In short, the SCS opened the entire sonic spectrum for me and was well worth the additional $300 (my price included the audiologist exam at Sensaphonics as well as the custom color). With my initial caveat in mind, I unreservedly recommend the SCS.
p.s. I forgot to mention all of the folks at Sensaphonics were a real pleasure to work with throughout the process.
How many hours of play time can you get from one full charge?
