Shure KSE 1500/1200 Confusion
Aug 10, 2018 at 11:22 AM Post #16 of 20
What they say?
"The KSE1200, as you pointed out, does not integrate a DAC like the KSE1500 system. It also does not offer the adjustable parametric EQ or input level meter, as there is no display on the unit. The KSE1200 system is designed to work with analog input sources only.
The amplifier and earphones for the two systems are the same."
Aug 10, 2018 at 11:47 AM Post #17 of 20
Nothing really new. I wish they would expand on their thought process more...
Nov 29, 2018 at 12:27 AM Post #18 of 20
Use kse1500 slider to select mode of INPUT. I can switch fastly the dac of SP1000 and the on inside kse.
Some bad of sp1000 has and some good that kse has.
Nothing completly perfection
What's that white thingy on the USB?
Nov 29, 2018 at 1:16 AM Post #20 of 20
Sp1k was transmitting digital to shure kse1500 (while 3.5 analog conneted too). I was comparing sq of kse internal dac to sp1k.
White part is otg adapter
lol. I have absolutely NO idea what you just said!
