Shure e3c Thoughts and Questions
- Thread starter BranMuffins
i'm staying outta this one until i hear the etys for myself. sorry muffins. welcome to headfi. don't worry, you'll get plenty of helpful responses soon enough.
i would strongly advise however, if this is really primarily an issue about the value YOU are getting out of your purchase, that you try not to search for other people's opinions on this. Only you can decide for yourself if what you paid, was money well spent. good luck.
BranMuffins
- Mar 27, 2004
- Messages
- 55
- Reaction score
- 10
I definatly understand what you are saying especially in light of the other debate going on around here. what I was really looking for is someone who went from e3c's to ER-4p's and what they thought. Everything that I have read seems to point to the fact that I would be happy with e5's but I simply cannot spring for those right now. So Im just wondering if I should go for the ER-4P or downgrade until I can spring for the e5s or perhaps even something nicer.
.chris
Originally posted by toaster22 i would strongly advise however, if this is really primarily an issue about the value YOU are getting out of your purchase, that you try not to search for other people's opinions on this. Only you can decide for yourself if what you paid, was money well spent. good luck. |
.chris
TMC
- Dec 27, 2002
- Messages
- 1,031
- Reaction score
- 10
Which sleeves are you using with the E3c? The echo or ringing effect is something I experienced with the grey soft sleeves and switching to the clear medium sleeves got rid of that not to mention gave the best overall sound for me. I suggest you fiddle around with the different sleeves a bit since it can take some time to find the one that suits you best.
br--
- Jan 23, 2004
- Messages
- 249
- Reaction score
- 0
I have tried both the e3c and the ER4. I was in exactly the same situation as yourself. I had bought the e3c but didn't think they were quite worth the money and I was very curious about what the highly regarded Etymotics sounded like. So I returned them for the ER4. What a difference!
The sound quality of the Etys is better in all respects. The Etys sound like someone lifted a pillow off the E3cs. You can finally hear detail. And it sounds wonderful and balanced.
The best thing you can do in this situation (in my opinion) is to give back the e3c's and get the ER4's. You will not regret it.
cmascatello
- Jun 14, 2003
- Messages
- 875
- Reaction score
- 10
If oyu have a return policy from your vendor then I would take a chance and swap the SHures for the Etys. If the E4 does not do it for you, then I would say go with the ER-6 and save up for the E5. The E5 seems to be the one that finally brings satisfaction to the canalphone junkies in here (save for Welly and lindrone
). I went looking for something a little spicier than the Er-4P and found it in the E5, although I still keep the 4P around for certain situations. Some other new E5 owners here (toaster22) would not trade their new babies for the world.
