koljaho
- Jul 31, 2005
as strong base as e2 ?
Originally Posted by birryboy /img/forum/go_quote.gif owners of both, did you have any similar problems? Is there a "definitive" tip for the e4s that will unlock that low end? Or do they really need burning in? |
Originally Posted by Spyro /img/forum/go_quote.gif I am NOT a fan of complys or foamies but something about E4's (and perhaps my ears), nothing sounds as good as the yellow foamies. Conversely, with my ER-4's, foamies don't work at all, tri-flanges are poor but the bi-flanges are perfect. Amazing because between these two IEM's the stem is just a hair longer on the Ety, there's really no other difference that should affect the tips. Goes to show you that getting the right fit and tip is crucial but once you get it, it's a snap. |
Originally Posted by vagarach /img/forum/go_quote.gif How about the fit with the E4? I had the E3's for a little bit and I could not stand them, left ear sealed comfortably, right ear would irritate and hurt and so on. I have the E2's and the fit is excellent, I can wear them for hours. Looking at the E4's they have the same basic shape as the E3's, so is the fit any different to the E3's then? |
