That a shame...
I heard that it works on win7, win10 but no luck on OSX.
I believe that when refreshing the database with the DX200, a file is placed on the card that tells the player what is currently on the card. This is likely what is causing your A+ to freeze when updating, as the file placed by the DX200 is not recognized. You might need to enable "View Hidden Files" on your computer to see it.
Only other thought is to try a different card and add several files at a time and see what happens.Ok, bad news
So, I've opened the micro-SD card in Windows 10 file explorer (using a microSD card adapter).
I've enabled the 'show hidden files' function (which revealed nothing new) and I've deleted the firmware update files from both Shozy and iBasso.
I tried the card in the Alien+ again, and it still didn't work.
I then accessed the card again in Windows, this time searching the folder for .jpg, .jpeg and .png files.
I found a few .jpg files and deleted them.
I also did a search for any files of 0-10kb and 10kb-16MB and only found two system files which are part of the microSD's FW I guess. They would have been there from the very beginning, and until now the card has always worked. So I didn't delete those, but I did delete the .jpg files.
But still, every time I do the 'media library initialisation' function, it just starts scanning the number of files, then freezes after a minute, showing this:
"find: 02079"
The only way to get out is to click the reset button on the left side of the unit.
Any other ideas? This really sucks. I can listen to all the files and folders that were on there before I added new files and folders to it.
But I really want to listen to the new stuff too, which all works fine on my DX200.
Heeeellllllpppp please? >.<
Coincidentally, I just tried adding an old micro-SD card. It was the card I originally used with the Alien+ when I bought it, and I haven't added anything to it since I last used it in the Alien+.Only other thought is to try a different card and add several files at a time and see what happens.
Have you tried reverting to the July firmware?Coincidentally, I just tried adding an old micro-SD card. It was the card I originally used with the Alien+ when I bought it, and I haven't added anything to it since I last used it in the Alien+.
This tells me that it is probably not an issue with the micro-SD card (since I got exactly the same error message), but possibly an issue with the FW update?
@NLNH Could you possibly look into this and let me know if you find anything?
It specifically concerns trying to update the media library after installing the latest FW update.
It freezes partway through giving the error message:
"find: 02079"
Note that it stops in the same place and gives the same error message on two Sandisk Ultra micro-SD cards; one 64GB and one 200GB, each with different files and folders on.
"find: 02079"
Does anyone know where a leather case for the Alien+ might be got?
here for example https://www.etsy.com/listing/558872943/shozy-alien
you can contact this case's maker and ask for modifications (different design, some other leather, and so on)
how's it?
