Shanling UP5 - Our new flagship portable Bluetooth DAC/AMP
Jun 16, 2021 at 7:28 AM Post #17 of 638
Ace Bee
India
@Shanling
So if I understand correctly, if charging is turned off while being used as USB DAC, then battery will eventually die and device won't work until charged again?
If the battery charged already, then that charge should remain.
Jun 16, 2021 at 8:43 AM Post #19 of 638
Ace Bee
India
Jun 16, 2021 at 9:35 AM Post #20 of 638
prbda
Poland
Indeed, I would love to be able to use it as USB DAC without exploiting the battery. And I would be doing this a lot, so if it's not possible, it might be a deal breaker for me.
Which is sad, because other than that the device looks like exactly what I need right now. (assuming it will sound good of course :wink: )
@Shanling Is there even a remote chance that such a feature could be implemented on firmware level?
Jun 16, 2021 at 4:00 PM Post #22 of 638
Ab10
IND
It is basically Shanling M3X without DAP function....Love to get one if it available in my country.
Personal import Ban in my country from neighbor.
Jun 16, 2021 at 9:07 PM Post #23 of 638
Shenzhen, China
@Shanling
I'm not exactly sure what set up are you looking for.
UP5 has two options:
- Charging On, UP5 runs on battery and battery keeps recharging while being used as USB DAC.
- Charging Off, UP5 runs on battery and is not charging. So yes, it will in the end run to zero.
If you want USB DAC that is not using battery, I would recommend to get UA2. And then get UP4 for Bluetooth. You end up at the similar price and sound quality as UP5.
Does it have microphone, for calls?
Yes, there is build-in microphone for calls.
Jun 17, 2021 at 11:24 AM Post #24 of 638
killaHz
Previously known as Matthew420
Los Angeles
Huh. I had been super tempted by the M3x, but it would be a lot better for me to use something like this with my phone instead. Same basic output circuit as the M3X, I guess.
How well does the current output stack up to the task of driving low-impedance planars?
Jun 17, 2021 at 7:12 PM Post #25 of 638
tjm6983
Looking forward to the UP5 release. Love the UP4 for workouts and will use one for home and one for the road. I pair the UP4 with a modest Soundmagic E11 and the combo has been indestructible as far as being impervious to sweat. And the sound quality for such an inexpensive setup is surprisingly good. Hopefully, the UP5 is equally workout worthy.
Also have the M8, which goes great with my Noble K10s, so I’m a big Shanling fan.
Jun 17, 2021 at 7:55 PM Post #26 of 638
Nealz
Bangladesh
Not exactly sure on the release date, will post once it's settled.
@Shanling I bought a brand new Shanling UP4 from your authorized distributor in Bangladesh: Gears for Ears. The first one had a cosmetic defect so the retailer arranged a replacement for me as I have 1 year official warranty. But the next two boxes they opened for me had even worse cosmetic defects. They gave me a unit as a replacement which has its color off at the bottom and there's a dent in the plastic bottom chin.
Even though I love the audio quality and battery life of my UP4, I am extremely disappointed in your quality control. How can you sell these units which have such bad cosmetic defects? I really hope you can provide a solution for me as I am feeling like I have just wasted my 90 dollars.
Jun 17, 2021 at 7:58 PM Post #27 of 638
holsen
Vancouver, Canada
Interesting> Sounds like there must have been a funky batch go to Bangledesh. I've had UP2 M5s and MX3 so far and they've all been flawless.
Jun 17, 2021 at 8:00 PM Post #28 of 638
Nealz
Bangladesh
Yes the retailer told me the same thing, that probably their whole batch is defective. But I'm the sufferer at the end of the day cause I'm not even getting a replacement or my money back even though they are providing a 1 year so called official warranty.
Jun 17, 2021 at 8:04 PM Post #29 of 638
holsen
Vancouver, Canada
Hope shanling reads and intercedes for you. Why don't you send them a PM and tell them the whole story. They'll see the discussion started here and can follow up with you privaely. That's probably the most "pro" way to go about it.:xf_cool:
Jun 17, 2021 at 9:01 PM Post #30 of 638
Shenzhen, China
In balanced output UP5 can do 240mw@32 ohm. If that will be enough or not can vary from headphones to headphones and also your preferences.
I'm sorry to hear this. But not sure why you posting about it in UP5 thread?
Please email me some details to Frankie@shanling.com
