Shanling UP4 & UP2 - Bluetooth 5.0 DAC/AMP with ES9218P, balanced output, supporting LDAC, HWA LHDC, aptX HD, aptX Low Latency, aptX and AAC.
Jul 7, 2022 at 9:29 PM Post #1,396 of 1,408
Shenzhen, China
Hi shanling, i tried re-pairing after unparing and re-installing the app several times. My shanling up2 still doesn’t hold the volume memory setting. The rest of the info does show up and i can use the EQ function. So it’s only the volume memory setting that keeps on shutting off. Is there a fix for this problem?
Not a issue we would be aware of. Would you be able to test it with Shanling controller app on Android?
Jul 10, 2022 at 10:01 PM Post #1,398 of 1,408
Shenzhen, China
Thank you for the response. After connecting the up2 to a android phone i could flip the switch for volume memory. After this the volume memory stays on even after re-connecting it to the iphone :)
Will report it to software team for check on iOS.
Aug 7, 2022 at 9:11 PM Post #1,400 of 1,408
Shenzhen, China
Can I use UP2 as USB DAC with Android devices?
Yes, if the Android device supports USB DACs, UP2 will work as USB DAC with it.
Aug 8, 2022 at 9:12 PM Post #1,402 of 1,408
Shenzhen, China
Aug 16, 2022 at 8:23 PM Post #1,404 of 1,408
Shenzhen, China
Hi,
Mine is a quite simple question. What does car mode do?
Designed for semi-permanent installation in car, when device (UP2 for example) is connected to charger at all times.
When enabled, once you start car and charger starts charging, UP2 will turn on automatically. Then when you shutdown, charger stops, UP2 will automatically tun off after a minute.
Sep 21, 2022 at 5:24 AM Post #1,405 of 1,408
Shenzhen, China
