Shanling UP4 & UP2 - Bluetooth 5.0 DAC/AMP with ES9218P, balanced output, supporting LDAC, HWA LHDC, aptX HD, aptX Low Latency, aptX and AAC.
Apr 21, 2020 at 10:06 PM Post #841 of 1,366
lionxsound
Can you please try different USB port on your computer or even different computer?
Do you hear same when used as Bluetooth receiver?
Tried different computer and tried using bluetooth connection same result, its just a brief hiss though.
BTW this problem happened if i connecting up4 to my active speaker using aux cable but when i plug my iem to the DAC there is no issue, although still there is a brief hiss but its so soft nearly inaudible.
If possible i want to asked for the future update to make jack 3.5 port also work as line out too? i think the hiss problem bcause of double amping
Apr 22, 2020 at 1:54 AM Post #842 of 1,366
Shenzhen, China
There can be some slight background noise with UP4, it might be just some mismatch with too sensitive active speakers? Can you please tell me what speakers are these?
ES9218P doesn't have dedicated circuit for direct line-out from DAC.
Apr 22, 2020 at 2:18 AM Post #843 of 1,366
ClieOS
IEM Reviewer Extraordinaire
Mid Johor, Malaysia
Sound like a ground loop issue to me. Get yourself a ground loop isolator, they are generally cheap so you won't be risking much money.
Apr 22, 2020 at 3:23 AM Post #845 of 1,366
lionxsound
I use Acoustic Energy Aego M 2.1
I hoped it can be fix in the unit itself before i try other method. But thanks for the suggestion
Apr 22, 2020 at 3:53 AM Post #846 of 1,366
Shenzhen, China
@Shanling what about Linux? Will you fix issue with 44.1 khz usb dac?
Software team is looking into it. They told me it works fine on Ubuntu 16.04 they managed to get for test, looking to try it on some other variants soon.
Apr 22, 2020 at 4:26 AM Post #847 of 1,366
Shenzhen, China
Apr 26, 2020 at 10:48 AM Post #848 of 1,366
chokini
France
Hello @Shanling,
Since my UP2 was updated to firmware 1.7.3, BT volume is limited to a low level when UP2 is paired to Ubuntu 18.04 laptop (codec is aptX-HD).
It gets more than loud enough in USB DAC mode. Playback from an Android phone (AAC codec) is fine too (after a new pairing).
Can you confirm that there is an issue with firmware 1.7.3 ?
Apr 28, 2020 at 10:46 AM Post #851 of 1,366
johnchpark
South Korea
Will you be releasing IOS app for the UP4?
Also, I saw the Android app Equalizer only has 5 bands (63, 250, 1k, 4k, 16kHz). Could you expand it to have more bands, or even parametric eq?
Thanks!
UP2 and UP4 users, Shanling controller app is now available on Google Play Store!
When you search for it, search for Shanlingcontroller (one word, without space). Small glitch that should be fixed soon.
Store link: https://play.google.com/store/apps/details?id=com.shanling.shanlingcontroller
Apr 28, 2020 at 9:13 PM Post #852 of 1,366
Shenzhen, China
Thanks!
iOS version is in works.
Not sure about current plans for EQ.
Apr 29, 2020 at 10:52 PM Post #854 of 1,366
Shenzhen, China
Hello @Shanling,
I had the same issue with 1.7.3, @chokini , but have thus far had no response or acknowledgment regarding it. In the meantime I had to revert back to the earlier firmware.
We are looking into these reports, but we are limited in testing linux.
