Shanling M9 Announced - Flagship High-End Portable Player
Nov 21, 2022 at 1:26 AM Post #1,218 of 1,351
New Firmware Update V1.55 for Shanling M9
Adding Roon support, improving system performance and other smaller adjustments.
Full notes and download link on our website, OTA ready: https://en.shanling.com/article-M9V155.html
Nov 21, 2022 at 2:10 AM Post #1,219 of 1,351
Nov 21, 2022 at 2:28 AM Post #1,220 of 1,351
Roon and Roon ARC seem to be working fine. :)
Nov 21, 2022 at 2:51 AM Post #1,221 of 1,351
I’m getting message Network request failed when attempting to request the update via OTA. Any advice?
Edit: now it’s working :)
Nov 21, 2022 at 5:02 AM Post #1,222 of 1,351
Hello,
I've just installed the new firmware and restarted, and now I get the following each time I change to Prime Mode:
The Shanling app runs fine when in Android Mode.
I've tried reinstalling the firmware and restarting but I'm still seeing the same problem.
Any help would be greatly appreciated. Thank you.
Nov 21, 2022 at 6:50 AM Post #1,223 of 1,351
Hello,
I got the same thing, I had to end up doing a factory reset which sorted it out.
Nov 21, 2022 at 7:01 AM Post #1,224 of 1,351
Thanks for the suggestion, vilhelm44. I've just tried a factory reset but I still have the same problem.
Another bug is that some of the setting options in the Shanling app are still in Chinese even though I've chosen English as the system language.
Nov 21, 2022 at 7:15 AM Post #1,225 of 1,351
Another bug is that some of the setting options in the Shanling app are still in Chinese even though I've chosen English as the system language.No problem, sorry to hear
No problem, sorry it didn't work. I haven't noticed any other issues. Hope you manage to get it sorted sap.
Nov 21, 2022 at 7:47 AM Post #1,226 of 1,351
Actually, my Shanling App has crashed again so it doesn't seem to be working after the firmware update.
@ Shanling, any ideas how to fix this please? Are we able to roll back to previous firmware?
Nov 21, 2022 at 9:41 AM Post #1,228 of 1,351
Thanks again, vilhelm44, will give that a try tonight.
Edit
I've just reverted back to the 1.53 firmware and it's fixed the crashing issue. Thanks vilhelm44.
@Shanling I will send you 2 log files from the crash, in case it is of any use to you to fix the bug.
Nov 21, 2022 at 9:54 PM Post #1,229 of 1,351
Hello,
Sorry for this. If you wish to return to older version due to Prime mode issue, here is link to V1.53
https://drive.google.com/file/d/1lvjrgLbiFM7yOUyuo184G1hVOoNWgNQl/view?usp=share_link
And the translation for USB function, it was supposed to be all in English (With all languages releasing with next Update), seems it got stuck in Chinese by accident.
Nov 22, 2022 at 1:03 AM Post #1,230 of 1,351
Thank you, Shanling. I've now installed the V1.53 firmware and the Prime Mode is working again.
