Turntable-T
Will the Shanling M8 have gapless playback for the seamless listening of live albums and DJ mixes?
I'm wondering about this too? I think it must mean you can select which model you want, rather than interchange whenever you want, so the advertising copy might be a bit misleading. If it's truly interchangeable though... wow, how does that work?!Interchangeable headphones sockets mean.....an adapter of an adapter for the socket ? 0_0 whose idea was it ? I rather prefer onboard direct or direct soldered on wires
As it says unique system, patent pending, it’s got to be something more than just being able to select the model you want.I'm wondering about this too? I think it must mean you can select which model you want, rather than interchange whenever you want, so the advertising copy might be a bit misleading. If it's truly interchangeable though... wow, how does that work?!
Technically it can easily be done. For example, a locking mechanism (push-turn-twist-pull-snap in...etc..) that is recessed into the chassis and headphones sockets can simply be made into modular to accommodate the locking mechanism. The question here is that it is no different than using “Adapter”, then why ?As it says unique system, patent pending, it’s got to be something more than just being able to select the model you want.
8 Pro 1999Want. I guess the price will be $999
Neater I'm guessing, although I'd imagine it places some level of risk of failure in the device itself, rather than a cheaper adapter. Just speculation really at this point though, and I'm all for innovation and new ideas so it looks really interestingThe question here is that it is no different than using “Adapter”, then why ?
How about an 8Pro-SE (Special Edition)8 Pro 1999
Because of Snapdragon 430 ( 2015 SoC) , forget about Android 9.
And with 4GB RAM , knowing Android use at leat 2 - 3GB RAM ...
Okay Ill take Android 10 lol. Is the 430 sdk locked down, akin to what fiio is dealing with on the exynos chip they prefer? Or is it some other google licensing issue?
