Shanling M3s - dual AK4490 DAC, 2.5 balanced out, aptX BT, HiBy link, USB out, FW 1.7
- Thread starter Shanling
- Tags
- shanling shanling m3s
I'm all in Chi-Fi. GR07 here sounds awesome btw.Thanks for the morning laugh...
I shouldn't talk though as I'm using a $1,600 IEM w/$300 cable and the M3s...does sound pretty good though...
how's your tempered glass? Mine doesn't stick on the upper left, and when I asked Jaben back there were being an ahole about it.
Do you guys know if I can LO from M3s to dac/amp via USB? Let's say if I want to connect to centrance dacport slim to a HD650 or K7XX. Will that work?
vinknight
- Dec 5, 2013
Just curious why would you want to do that?Do you guys know if I can LO from M3s to dac/amp via USB? Let's say if I want to connect to centrance dacport slim to a HD650 or K7XX. Will that work?
If i have a better amp/dac and I want to drive full size cans.Just curious why would you want to do that?
Yes, it works with my Violectric amp via usb OTG.
vinknight
- Dec 5, 2013
The m1 and m2s have USB out. So I assume it would be the same for the m3s. Would be weird if it doesn’t have this feature.If i have a better amp/dac and I want to drive full size cans.
bachankas
- Jan 30, 2013
I have the H6. They sound good with everything, and the M3s is no exception. It's a good combination and not at all fatiguing. (They're not very transparent/source-dependent, so there's not a huuuge advantage to using the M3s or an amp over using a phone.)
Re: battery life, I'm not sure. sometimes it seems like it depletes faster than I expect and sometimes the opposite. I suspect that the issue might be that that after charging, a full battery meter doesn't necessarily mean that the battery is actually full. I.e., if I just charge it until the meter shows full, then it will run down quickly, but if I leave it charging for hours or overnight, the meter will continue to show full for a long time. This isn't necessarily a flaw, but it's not quite what I'm used to.
Thanks for reply, I have H6 paired with M1 and it's almost perfect - only battery lasts too short for me and I had to buy small powerbank
I can confirm the M3s does allow output to an external DAC via its USB port, as you say it works the same as for other Shanling DAP's.
cleg
- Oct 14, 2011
My video about M3s
New firmware 1.2 for Shanling M3s
Google drive link: https://goo.gl/2TYHhu
New function:
1. HiBy Link app for iOS system released (beta test version), now any iOS device can be used to control the M3s. How to install guide is included in zip file.
Changes and fixes:
1.Fixed the problem of the M3s automatically connecting to Bluetooth headsets when Bluetooth is turned off.
2. Fixed the problem of having no sound when playback is restarted from standby mode.
3.Fixed the problem of the progress bar not moving during playback.
4.Fixed the problem of showing the Bluetooth pop-up window when playback is restarted from standby mode.
5.Fixed the problem when M3s couldn’t wake up from standby mode after TF card was pulled out.
6. Clock Lock screen was removed to assure more convenient usage. Now current time is displayed only on top of the screen.
7.Fixed other small system bugs
New function:
Changes and fixes:
Have any question about our players? Just PM me or send me email.
Stay updated on Shanling at their sponsor profile on Head-Fi.
drag0nslayer
Great thats the support we need for m3s
Thanks shanling <3
Thanks shanling <3
vinknight
- Dec 5, 2013
Testing the iOS app now. Album art preview is rather blurry. Could it be that my art is 500x500? And no more fiddling around with the dap in my pocket!1. HiBy Link app for iOS system released (beta test version), now any iOS device can be used to control the M3s. How to install guide is included in zip file.
deleted
