Shanling M3s - dual AK4490 DAC, 2.5 balanced out, aptX BT, HiBy link, USB out, FW 1.7
Discussion in 'Portable Source Gear' started by Shanling, Sep 1, 2017.
82 83 84 85 86 87 88 89 90 91
93 94 95 96 97 98 99 100 101 102
  1. Arum16
    Hi,
    On this subject. Would a .m3u file work as a costume playlist file?
    There are some Win based applications we can use to make such playlists.
    Thanks for any hints.
  2. DBaldock9
    At the root level of my memory card, I've created a folder called Music.
    In the Music folder, I've created a Playlists folder.
    In the Playlists folder, I place .m3u playlists, which have relative paths in them.
    For instance, a playlist that includes:
    Music / Christmas / Hinely, Donal / 1998 - Midwinter Carols - Fourteen Selections on Glass Harmonica / 1-02 Canon in D Major [Hinely, Donal].flac
    would have this line in it:
    .. / Christmas / Hinely, Donal / 1998 - Midwinter Carols - Fourteen Selections on Glass Harmonica / 1-02 Canon in D Major [Hinely, Donal].flac
    Currently, I use some Linux bash scripts to create the playlist files, but any program that can be configured to output relative file paths should work.
    riffrafff likes this.
  3. Arum16
    Thanks DBaldock9.
    Linux does it, was thinking exclusively Win10:blush:.
    Got my M3s today. Nice!!
    Knocking my socks off with some Kraftwerk:smile_phones:. Transitioning from my oldie Cowon X5L.
    Very first fresh impressions' quite good. Getting to know the UI.
    DBaldock9 likes this.
  4. DBaldock9
    Currently, I use Cygwin on my Windows 7 PC, to have a Linux command line, for developing & running my bash shell scripts.
    http://www.cygwin.com/
    I also have a 2011 Asus Eee PC Netbook, that runs Mint Linux, but it's not very powerful.
    The M3s works well as a USB connected DAC for the Lunux PC, but streaming music from YouTube tends to use up quite a bit of the CPU power - especially if that tab is open, with the video playing as well.
    Once I move next month, I'm going to begin checking on an an actual Laptop, with a 4-core processor, that can run virtual machines.
  5. jmac1516
    Just opened my M3s and I must be doing something wrong. I can’t get my micro cards to stay/lock into the M3s slot. Anyone have a similar issue?
  6. Pete7874
    Dumb question, but are you inserting it the correct way? It goes in face down.
  7. jmac1516
    Yes, upside down. It goes all the way in if pushed, but wont lock in.
  8. Pete7874
    You have to use your nail to push it in deeper, past the shell of the DAP.
  9. jmac1516
    I did that too. I used a thin piece of plastic to help push it in past the shell. Still would not lock in.
  10. Pete7874
    That's odd. Try another microSD card. If you're still having the same issue, maybe there is something wrong with your DAP.
  11. twister6 Contributor
    did you hear it click?
  12. jmac1516
    I’ve tried several cards and none will click in.
    @Shanling: any known issues similar to what I am experiencing ( I.e. cards will not click into slot)?
  13. superuser1
    Maybe the locking mechanism inside is faulty and you need to ask for a replacement if thats possible.
  14. jmac1516
    Very possible. I sent a note to Musicteck so I’ll see what they say.
  15. twister6 Contributor
    did it ever work before or is this your first time using the dap?
