kukkurovaca
- Apr 7, 2017
Definitely concerning to hear about issues with the scroll wheels already, since it's a part that's going to see extremely high use through the lifespan of the device.
FWIW, I had my M3s connected to my Nexus 5X phone... streaming from Youtube, Slacker, Plex... I did not notice any strange noises.So M3S supposes to have those noise when use the bluetooth function ?
I don't know how similar the design of the wheel on the M3S is to that of the original M3, but my wheel came off the M3.
It would be great to hear from Shanling on whether this is a known issue and how prevalent it is. Also how they will handle customers who experience this problem.
So M3S supposes to have those noise when use the bluetooth function ? Or my M3S is defective ? @Shanling
Have any question about our players? Just PM me or send me email.
Stay updated on Shanling at their sponsor profile on Head-Fi.
So i think something is wrong with my unit. I just did a factory reset. The noise still remains but not as loud like before. I think i will contact Musicteck tomorrow.Answer is obviously no. As I posted, on my M3s units I can hear some sound lasting for fraction of second when playback starts, definitely not a minute long. I was unable to recreate your problem on multiple devices in our office. Neither did I saw similar comment from other users here. So I'm afraid, that you might have something wrong with your unit.
I would recommend these things as always - reset unit, restore factory settings, try to go back to some of previous firmware.
Ok guys, I could use a little help. Got the M3s a couple of days ago. This is my first proper DAP. I've been using iTunes and an iPod for years, so this file management system is completely new to me. I've been slowly migrating album by album from iTunes and think I finally got the artwork side figured out.
BUT, I have quite a number of multi disc albums, and after transferring a few I took a look them in the MY MUSIC section - both under ARTIST and ALBUM. The play order was a jumbled mess. The first song on Disc 2 would be second in the cue instead of the ninth, etc. So, I went back into iTunes and changed all the Disc and Tracks tags so that It read as a single disc with many tracks in order. Deleted the old folder from the M3s, imported the corrected one and STILL under any category in MY MUSIC, the same jumbled play order! After being driven crazy for a while, I got the idea to look at the same album in the FILE BROWSER, and there the tags and play order were absolutely correct!
I then tried importing a multi disc album WITHOUT changing any tags, and sure enough in FILE BROWSER they are listed correctly in proper play order, but again, in MY MUSIC - they are not. Why is that? Obviously, I'll have to use FILE BROWSER exclusively for now and not have any of the features of MY MUSIC. Does that seem right? How do others deal with multi discs?
One other thing, I would like to be able to pause a track and then skip through tracks while STAYING paused until I press play again, like cueing up the beginning of a particular song and then start playing when I choose to. The M3s doesn't appear able to do this, it doesn't hold the pause. This should be a basic player function. Any insight is appreciated.
I'm having scrolling wheel issue from the start specially for download scrolling but that time i just ignored it but now it feels like my downward scrolling is getting bit loose as if i scroll single it scrolled double or more but on upward scrolling wheel is okay with ticks. So, in short its getting loose and i just contacted my seller and he is saying that shanling saying about return it then i should return to them and they will send it to shanling. Now should i send it to my seller ?Since this thread is not flooded by broken wheels comments, but only single digits of users with this problem, I think it is quite uncommon. As any mechanical part, it can in some cases fail. If that happens it's fully covered by warranty and you only need to contact your dealer/distributor for replacement unit.
Shanling?My small gripe with the wheel is that it lacks consistency in its response... sometimes one click/turn of the wheel will cause it to jump two steps (either in volume or going up/down a file list) and sometimes it will only advance one step.
Is it just mine or do they all do that?
Nope. Im using latest fw right now.And tried different firmware too?
