Shanling M3s - dual AK4490 DAC, 2.5 balanced out, aptX BT, HiBy link, USB out, FW 1.7
May 23, 2019 at 2:12 AM Post #2,116 of 2,219
Hi -@Shanling,
Sorry to bring this up again. Could you please clarify?
For M3s to function as USB transport into a standalone DAC, is this how it should be set from the menu?
System settings -> USB Mode == DAC
File Browse -> OTG (DAP asks for "Please Insert OTG)
From here, how do I select the tracks?
I'm pretty much in the dark on this,
Thanks for your help
To use M3s with external DAC, simply connect matching USB cable, there is no need to go to settings.
USB Mode is setting to use M3s as DAC with computer.
OTG in file browser is usable, when you want to play files from external memory connected over USB.
May 23, 2019 at 4:33 AM Post #2,118 of 2,219
Xie Xie Frankie,
So in order to play my music from my SDXC card, (streaming it into a DAC) DAP wise it's just the same.
I'll be using the player's functions as usual.
What is the USB-C limit? PCM 24bit? PCM 32bit? I'll have a DAC that has USB-B at PCM 32bit/768kHz; DSD512 / 22.5MHz
May 23, 2019 at 5:33 AM Post #2,119 of 2,219
Xie Xie Frankie,
Yes, you will use the player same as always, just instead of headphone port it will be outputting to USB connector.
USB output should be capable of all formats that M3s can do, so PCM 32 and DSD 256.
May 27, 2019 at 9:08 PM Post #2,122 of 2,219
Is the official M3s leather case still available?
M3s and its accessory was discontinued last summer, so now its up to finding some stock at dealers.
Jun 23, 2019 at 8:10 AM Post #2,125 of 2,219
My M3s worked untill now, one year and a half. I had only problems with wheeling knob, was not stable. But yesterday I tried to turn on and only grey screen appeared with factory logo, than disappeared for a second, than reappeared. After about one minute try to upgrade a new software and returned to the beginning. Is repeating this procedure ad infinitum. So I presume the software is frozen. I have no idea what to do, and I'm very unsatisfied with its quality. I bought it directly at Shanling shop via aliexpress, so I couldn't claim the guarantee rights in Poland. Please, advice me what to do!
Jun 23, 2019 at 1:02 PM Post #2,126 of 2,219
I bought mine about the same time as yours (November 2017).
A few weeks ago, it got stucked on a boot loop: After power on, Shanling logo showed up followed by a click and a new boot sequence. Over and over.
I left it charging for two hours and the problem got solved.
And yes, the turn wheel is its weak point. Mine is somewhat erratic. I work around it, by using the Hiby Link app on my phone over bluetooth connection. I'm still on version 1.30
Hope this helps somehow
Jun 23, 2019 at 9:47 PM Post #2,127 of 2,219
Anyone have experience connecting the M3s to a Fiio DAC/AMP via USB? The M3s doesn't work with my RHA. Or a Topping?
This is all about the USB input on DAC. Some of them demand more power, some of them drivers, some want to interact with computer.
For such software issues, you can uses "cloner" software to reflash firmware on device, should solve this problem.
Download cloner: https://drive.google.com/open?id=1tHsHuQp2a4cUr4WsvB3hGwO_ktYTNmGX
And special version of firmware for cloner: https://drive.google.com/open?id=1dWNwlJL6YVDQE6CARklx67OVr7rHEa0m
Jun 28, 2019 at 6:11 AM Post #2,128 of 2,219
You're right. Finaly DAC turned on with no intervention from my side. Thanks for info :). It's obviously one of the Murphy's law
Jun 28, 2019 at 6:25 AM Post #2,129 of 2,219
Great to know it all got sorted out ok. Those laws of Murphy's are a real pain!!:confounded:
When it happened to mine.. my heart just sunk link a stone. It was a great relief when the M3s came back up running as good as usual.
Jul 5, 2019 at 6:50 AM Post #2,130 of 2,219
Hi @Shanling,
Could you please clarify one point?
I'm feeding an SMSL SU-8 DAC from my M3s via USB port.
My chain is Shanling M3s [USB_port] ---> SMSL SU-8 [XLR_ports] ---> LOXJIE P20 [XLR_port] ---> HD6xx hp
The volume knob on the M3s changes the volume level at the end CANs
The signal coming out from the USB port on the M3s unit goes through an amp stage? Being that this signal is to be feed into a DAC, wouldn't it be streamed out as digital signal still?
I am obviously too "green" on these matters, could you please clarify?
Thanks
