Shanling M2x - TIDAL || Wi-Fi || Both-way LDAC BT & BT Transmitter || Advanced USB transport || FW 2.7
Feb 22, 2019 at 4:00 AM Thread Starter Post #1 of 714
Shenzhen, China
Shanling M2X Reviews in post #2
Shanling M2X firmware updates in post #3
Soon it will be 1 year since we revealed Shanling M0. Flagship Shanling M5s was announced just 6 months ago. Now it’s time to fill the gap between them with a new mid-tier player. And what could be a better fit than third generation of popular M2 model?
Introducing Shanling M2x
Shanling M2x is smaller brother of our current flagship Shanling M5s. Same beautiful design, MTouch system and rich feature list. And while M5s stays as our top model thanks to its superior sound quality, M2x will be tempting alternative for anybody looking for slightly smaller and cheaper player.
Shanling M2x comes with few new features:
- Tidal support – For never-ending streaming of music (ONLINE mode only)
- USB Bluetooth transmitter – For high quality wireless sound from any computer
- Advanced USB output – For use with any external USB DAC, now including compatibility with DLNA, Airplay and Bluetooth receiver modes
Key specifications
- 3.2’’ touch screen and Shanling’s MTouch 2.0 system
- DLNA, Airplay and Bluetooth for wireless connection with smartphone & computer
- USB Digital out for use with external DACs
- Serves as USB DAC and as USB Bluetooth transmitter
- AKM AK4490EN DAC and balanced output
- Slot for micro SD card, compatible up to 2TB
- Hi-Res music support up to 32bit/384 kHz and DSD256
Visit our website for more information about Shanling M2X
Feb 22, 2019 at 4:02 AM Post #3 of 714
Shanling M2X Firmware V2.5 notes
You can now update with OTA update or download from Google Drive or our website
New functions:
1. Added ReplayGain function. Go to Playback menu to enable.
2. Added Playlist Import / Export function.
Notes:
- Works with .m3u playlist files.
- Playlists will be exported into “_explaylist_data” folder in root folder of Micro SD card.
- To import user created playlists, put .m3u file into “_explaylist_data” folder in root folder of Micro SD card and click “Import playlists” in Playlist menu.
- We recommend to export one playlist from your M2X and follow its formatting for user created playlists.
3. Added quality settings into Tidal app.
4. Added new theme (Theme 2)
5. Album cover and lyrics can be downloaded from internet and added to currently played file.
Note: Tap on now playing screen and tap on last icon on right (icon of CD).
Changes and fixes:
1. Improved Equalizer performance, limiting distortion when using high level of adjustment.
2. Album browsing submenu now recognize external jpg files as album covers.
3. Playing interface can be quickly changed directly on Now Playing screen. Tap icon in upper right corner.
4. All Songs browsing now shows Artist name.
5. Added date setting. Date is displayed on lockscreen.
6. Improved performance of Lyrics function.
7. Fixed problem of unit not charging to 100%.
8. When Sleep timer is set, system wait until currently played song ends and then automatically turns off.
9. Optimized screen brightness, now can be set for lower level for use in night.
10. Improved font files to avoid problem with some special symbols from different world languages.
11. Other bug fixes.
Feb 22, 2019 at 8:17 PM Post #6 of 714
Feb 23, 2019 at 5:14 AM Post #7 of 714
Well, with only an “X” for a designation as opposed to a letter and a number, I’m expecting a weird new AIO device or the start of a new product type.
Feb 23, 2019 at 4:12 PM Post #10 of 714
The tags at the top give some hint at what kind of device this is.
Though that list would also apply to the M5s I believe.
Not quite, since the M5s doesn't have direct access to apps like Tidal (unless I've missed something).
Perhaps this X player will be Android powered...a rival for FiiO's M6 or M9?
Feb 25, 2019 at 10:01 AM Post #15 of 714
