It is on FW 2.7.
Current firmware for M2X is 3.0, so please update https://en.shanling.com/download/63
Have any question about our players? Just PM me or send me email.
Stay updated on Shanling at their sponsor profile on Head-Fi.
It is on FW 2.7.
We are not seeing such reports form other users right now.
Please try to do factory reset of the player and log in again into your Tidal account.
any chance the M2 series becomes the Q2 series going forward.
It would make sense to me to have the non-android DAP's be the Q series and the android DAP's stick with the M series. This would make it easy to know what OS each DAP release has either MTouch or android. I could see a Q2 with maybe a slightly larger higher res screen ,the new ES9219C DAC/Amp in place of the older 9218, bluetooth 5.0, etc...
For me not wanting android the Q series will be the one to watch for future developments
3. Other bug fixes
I'm curious why you want to avoid android?
Hello @Shanling,
I have an issue with the M2x player. When it's on, the display screen will stay on for 20 seconds, then turn off for a second or so, then turn on again for another 20 seconds, and keeps repeating like that. The screen never shuts off and stays off, except when I turn the player off. I just updated the firmware but it didnt help. I looked at my settings but couldnt figure out what could cause this issue or how to change it. Could you help? Thanks!!
Please check how you have set idle settings for screen. Try to set it to off and to different values, if it will repeat.
No, in idle setting, if you swipe left, you will get to standby/shutdown and then Screen off setting.Thanks for your reply. So, do you mean "Idle - Sleep Timer"? I took a look at it. It was set to "off". I turned it on, and set it at different amounts of seconds. It didn't change anything, the screen continues to turn off after about 20 seconds, stay off for a second or two, and then turn on again, and keeps repeating like that.
So, for an hour or so, when I would push the button on the side, the screen would shut off for a minute or two, and then turn on again... while setting a certain amount of second in the Idle -Screen Off menu still wasn't working at all. Now, suddenly, everything is working as it should. Weird behavior. Anyway Idea why this might have happened, and anything I can do to prevent it from starting again? It seems like something mechanical may be on the fritz, I don't know. Anyway I'm glad that for the moment it seems to be normal again.
