Shanling M2x - TIDAL || Wi-Fi || Both-way LDAC BT & BT Transmitter || Advanced USB transport || FW 2.7
post-15094444
Post #301 of 587
SilverEars
@Shanling Any of your devices transmit from 3.5mm input? Will you ever add optical/3.5mm input for transmitting in the future? What are all the devices that transmits, and what is the highest bitrate codec in transmitting mode?
post-15094552
Post #302 of 587
chechu21
Spain
Spain
It doesn't work since you are following tutorial for completely different function.
To get M2X connected to your computer and to play music from Foobar over Wi-Fi:
Make sure devices are connected to same wifi and that DLNA is turned on in setting of M2X.
Install UPnP MediaRendered Output to your foobar
Choose "UPnP: Shanling M2X" from list of output devices, as you can see on this picture:
Now just start music and you should hear your sweet music.
Ok. I got it. But when i send music via foobar to the Shanling don't appear the title and artist. Only displays in screen: foobar2000 audio stream.
Is it any chance to develop any software DLNA DMP / DMR (Full player DLNA) to Shanling?
post-15095978
Post #303 of 587
Shanling
Sponsor: Shanling
Shenzhen, China
Shenzhen, China
No plans for optical output.
M0, M2X, M5s, all can do digital USB output, including Hi-Res and DSD.
Well, that is up to some settings in foobar. With other apps(for example Hi-fi Cast on my Android phone), M2X gets both information and cover of the played file.
Currently we have no resources to add more software for DLNA.
post-15096205
Post #305 of 587
Shanling
Sponsor: Shanling
Shenzhen, China
Shenzhen, China
I do not mean digital output. I mean take in analog through 3.5mm, and transmit via BT. This is useful for flights. Any of them do that?
Oh, sorry for misunderstanding.
For such function, you would need to build in additional ADC converters, which otherwise make no sense in our players, so we do not plan to add these.
There are some dedicated devices that can take analog and send out BT, like this unit from RHA https://www.rha-audio.com/us/products/accessories/wireless-flight-adapter They work with aptX.
post-15099682
Post #306 of 587
BeezBee
Earth
Earth
My M2x stopped charging at 99%, is that normal ?
I'm using recommended charger 5V 2A
Firmware v2.3
Edit: It can be fully charged 100% if i charging through PC or laptop
post-15099817
Post #307 of 587
bogginhead
Caution: Unreturned Tour Gear/Sells Borrowed Gear
Alabaster, AL
Alabaster, AL
Has anyone here had any issue with their 2.5mm balanced connection no producing sound with certain gear? I can't seem to get my Audeze Sine DX working with the M2x even with just a normal 2.5mm balanced cable; not sure what the issue might be.
post-15100462
Post #308 of 587
karloil
Singapore
Singapore
@Shanling
Any idea when your leather case stocks will be arriving in Singapore? Local retailer told me it will be arriving soon - but how soon?
post-15104629
Post #309 of 587
Shanling
Sponsor: Shanling
Shenzhen, China
Shenzhen, China
@Shanling
Not sure, last order with cases I see in our system was shipped to them at beginning of July.
post-15106794
Post #310 of 587
karloil
Singapore
Singapore
Ok noted. Will just follow-up with the retailer. Thanks!
post-15107533
Post #311 of 587
fish1050
Toronto, Canada
Toronto, Canada
@Shanling
any idea when the M2X will be available in Canada and what retailers will carry it?
post-15108511
Post #312 of 587
Shanling
Sponsor: Shanling
Shenzhen, China
Shenzhen, China
post-15108853
Post #313 of 587
ayres
@Shanling
Hey! I've been enjoying my m2x... it's a great little player. one small thing to maybe consider in future firmwares: holding and sliding where you are on the song's progress bar is not very smooth. another option would be to add 15 second interval buttons (or however many seconds).
keep up the great work!
post-15110532
Post #314 of 587
Shanling
Sponsor: Shanling
Shenzhen, China
Shenzhen, China
@Shanling
You mean that you wish for it to jump through song as you are moving slider? Not like now, when it jumps once you lift your finger?
15/30 sec jump button is something that would be more fitting for audiobook/podcast player (if it ever comes out from our software team), not something we would add to music player.
post-15114869
Post #315 of 587
ayres
Thanks for fielding my opinion! I should have made myself clearer. I am NOT referring to jumping through the song as i move the slider. I am referring to where the track plays once i lift my finger. Here's my example:
On a 2 minute song, the slider responds well to finger movement. However, on a longer track, say 15 minutes, pick a time (let's say, 4:25) and try to land on it (or near it) as you slide your finger back and forth along the bar. It's not not easy, and what I mean by that is, with my finger on the slider, i'll be at 4:50, and with the slightest of movements, the track jumps to 3:55.
What i'm trying to articulate is that on a longer track, sliding the progress bar lack precision and accuracy.
and i don't know if there's an easy solution (other than a jump button). part of the problem is the small screen; a larger screen will allow for the track to be distributed over a longer progress bar.
But i thought i would at least bring this up. i encourage others to add their opinions.
thanks!
