froes
- Mar 30, 2010
For usage as a mass storage device there's no driver needed.Anyhow, no drivers needed. Win 10 sees it as a drive, as I wanted it to.
It is only needed for usage as USB sound card/DAC.
Have any question about our players? Just PM me or send me email.
Stay updated on Shanling at their sponsor profile on Head-Fi.
But this still has the auto sleep mode, not auto power-off, right?
New firmware update for Shanling M1, firmware 4.2
New functions:
1.Added support of OPUS Codec.
Changes and fixes:
1.Higher speed of scrolling text.
2.Fixed other small system bugs.
Download from Google Drive or Shanling website
Let me tell you what this new firmware does, because nobody checked before they issued it. It breaks the M1 bluetooth function and the USB function so that the work around I posted on the last page no longer works. Thanks Shanling. As usual your quality software workmanship is just incredible. Truly.
They mentioned that this is impossible to select it from Menu. Thus, I suggest releasing two version of FW - one with standby, second with shutdown, problem solved@Shanling This should choosable by user to avoid such demands.
You did. But their response was basically that the Chinese market is bigger and more important than the overseas market and the Chinese market preferred standby vs off so they were only going to support standby.They mentioned that this is impossible to select it from Menu. Thus, I suggest releasing two version of FW - one with standby, second with shutdown, problem solved
