Eric Smith
Just cant wait to stream Tidal Hifi from my phone to the M1 and Mojo. I will have an endless supply of music.
All that music at your fingertips, and it does a pretty good job of it.
Any chance you could do a Battery life test for the M1 with Streaming Music always ON?
Amazon also typically has a rather forgiving return policy as long as you don't overuse it.
Yeah, I'm a Prime member and have rarely had to return anything, only headphone purchase I remember having to return was a brand new Fostex T50RP MK3 that literally came with a piece broken straight out of the box and I had a refund without difficulty and I immediately ordered a replacement even before the refund posted.
Seller on Amazon for the M1 is SHENZHENAUDIO, fulfilled by Amazon. Very tempted. I have a FiiO X1, considered upgrading to the X1ii but that has seemed to be recovering only slowly with firmware updates from UI and other issues.
The M1 seems to have every feature the X1ii has and more, though less power....
Well, for example, at half volume, I can listen to an HD700 on M1 with an enjoyable sound. I can achieve a higher quality sound from Opus #1, Hifiman Supermini or Chord Mojo, but I can most certainly reach an uncomfortable volume. It's kind of nice to be able to have something this small and portable that can drive anything I own, although my 320 ohm earbud might be at it's limit.
Seller on Amazon for the M1 is [COLOR=0066C0]SHENZHENAUDIO[/COLOR], fulfilled by Amazon. Very tempted. I have a FiiO X1, considered upgrading to the X1ii but that has seemed to be recovering only slowly with firmware updates from UI and other issues.
[/IMG][/IMG][/IMG]
Little is better!!! M1 plus Topping NX1A... Now the sound is louder enough!!!
