Shanling M0 - Nano size, touch screen, LDAC & aptX BT, USB DAC/transport and ESS Sabre ES9218P, FW 3.2
post-15431441
Post #5,851 of 5,897
ShaunP
uk
uk
extraction via 7-zip and windows explorer both had the same problem. I will try winzip.
No way?!?!?! That is a definite point off its score. You can map the wheel to stop/start but it still means fishing about in your pocked to change volume.
post-15433545
Post #5,852 of 5,897
deegodan
Anyone know if there is a way to send music from the M0 to an Android phone?
My use case is that I use a Pixel 3, so there isn't a ton of storage on it. I use an Audeze isine 10 with the cipher cable and the phone. The cipher cable won't work with the M0 (it also doesn't work with my dragonfly red either).
I'm assuming this isn't possible but I thought I'd ask.
post-15433555
Post #5,853 of 5,897
DBaldock9
Houston, TX USA
Houston, TX USA
Website
www.flickr.com
The problem isn't with the M0 - it's that the Bluetooth driver in most phones are only Sources, not Sinks.
I've been periodically checking to see whether there are any Linux Bluetooth drivers that can be "back-ported" to work in my LG V30 (rooted, running LinageOS), so that it will operate as an LDAC Receiver.
post-15434646
Post #5,855 of 5,897
oldschool
From the latest 3.2 firmware:
Shanling said:
4. Added battery icon into Lockscreen.
I think this resulted in a bug on my unit where when I turn it off it goes to the blue battery loading animation immediately after the goodbie screen! I need to keep holding the shut off button for another 10 seconds until the unit finally turns off. If unnoticed, this leads to silently draining the battery while you think the player is off.
Reactions: LaughMoreDaily
post-15440285
Post #5,856 of 5,897
deegodan
So, I've tested the USB output to:
Hifimediy USB Dac - Works
Dragonfly Red - Doesn't work
Audeze Isine Cipher Cable - Doesn't work
anyone else have similar results?
post-15440368
Post #5,857 of 5,897
DBaldock9
Houston, TX USA
Houston, TX USA
Website
www.flickr.com
These tests were done while clearing the BT pairings, between tries with the different devices?
post-15440636
Post #5,858 of 5,897
deegodan
I connected an OTG USB C male to USB A Female cable then connected the DAC/amps to it.
I didn't clear any Bluetooth pairings since bluetooth wasn't on and I don't think one would interfere with the other.
post-15440765
Post #5,859 of 5,897
DBaldock9
Houston, TX USA
Houston, TX USA
Website
www.flickr.com
You're right.
I misread your first post.
Sorry.
post-15440848
Post #5,860 of 5,897
technobear
Glastonbury, UK
Glastonbury, UK
Those DACs need more power than M0 can supply. You can only use it with self-powered DACs.
post-15443276
Post #5,862 of 5,897
Lord
Dear all,
I've had this M0 for 3 months now, updated to the latest firmware and I'm facing quite a problem here : When I switch it on, after about a minute or two, it stops itself, shutting down completely.
I have taken out the microsd, changed it, did a factory reset, charged it fully, nothing changes...
Did anyone here get the same behaviour ? I'm very disappointed with it, it was a gift to my wife to replace her dying Sansa clip and now she has nothing :frowning2:
Do you know if a firmware downgrade is possible ? This is a solution I did not test yet (even though the probleme happened week after the upgrade).
post-15443512
Post #5,863 of 5,897
lpt812
Dear all,
Have you checked the In-Vehicle mode is turned off in the main system settings? I had the same issue and turning that off fixed it
post-15443601
Post #5,864 of 5,897
filbert
UK
UK
Dear all,
Never had any issues with mine. If the suggestion re vehicle mode doesn't help, I'd say return it as it sounds faulty..
post-15444849
Post #5,865 of 5,897
endgame4
The Netherlands
The Netherlands
Yes, no problem. You can flash any other version like the latest.
Users Who Are Viewing This Thread (Users: 2, Guests: 7)
