Shanling M0 - Nano size, touch screen, LDAC & aptX BT, USB DAC/transport and ESS Sabre ES9218P, FW 3.2
Discussion in 'Portable Source Gear' started by Shanling, Mar 16, 2018.
213 214 215 216 217 218 219 220 221 222
224 225 226 227 228 229 230 231 232 233
  1. BillyX
    how long the restarting after click system update? is there any indicator in the m0 screen being updating? you now like a bar or something, thanks
  2. Kris77
    Copy update file to a blank memory card and start updating - the card should only contain a update file.
  3. ShannyM0
    Why does the battery show up as discharged when you use it, then fully charge it and then it doesn't seem to update right away so it shows as red and discharged but the battery is really full then? If you plug it back in, it then starts to "update" the charge state. and fixes it but it is still wrong for a while. Firmware 2.1.
  4. zaero69
    looks like you got the faulty unit
  5. 329161
    Is there the possibility of using the M0 as a Bluetooth receiver and outputting the audio to listen via external dac/amp?
  6. endgame4
    Currently this is not possible.
  7. afico
    Any suggestion about an iem that pairs well with m0 in order to have an open and neutral sound ?
    I was thinking about fiio f9 pro or Ibasso it01
  8. RockStar2005
    Hi Shanling,
    In HIGH Gain Mode, what is the max impedance your M0 device can drive?? Please let me know in detail.
    Thank you!!
  9. 329161
    Depends on the sensitivity of the headphone as well ie the db/mW it outputs.
    RockStar2005 likes this.
  10. RockStar2005
    Ok so 250 ohms and 102 dB/SPL (1mW/500Hz).
    Please let me know for High Gain mode what is the max it can drive.
    Thank you!!!!!
  11. 329161
    Bummer. This would've turned the Mojo into a virtual Poly Mojo.
    Hi @Shanling.....feature request for the M0 to be able to be usd as a transport into a dac/amp outputting audio received from Bluetooth, along with AAC Bluetooth transmission. Cheers.
  12. Dobrescu George
    That would be a maybe.
    Initially, I was going to say now, or not really, but then I connected LCD-MX4 to M0 right now to do a test for you, and I am quite happy with the music, it can drive some headphones well. from you descreiption, you're trying to drive Amiron, by any chance? that requires more power than Mx4...
  13. RockStar2005
    Hey George!
    I C. No I'm driving my 250 ohm Beyerdynamic DT 1770 Pro (102 db/SPL sensitivity).
    I just a bit ago found this review by Headfonics (see excerpt below) which basically proves it can't handle 250 ohms. So I think when I upgrade my LG V30 to my next phone (which very likely won't be an LG with Quad DAC) I will have to instead buy the Ampio G1 VD-6880, which can most definitely handle well over 250 ohms.
    Driving Power
    The specs say it is recommended up to 300ohm and I intensely disagree with anyone recommending anything that difficult to drive for usage with this M0. It struggles with 120ohm and does not have nearly enough power to do justice to needy headphones. Stick with typical portables, 32ohm and under, maybe even up to 80ohm and you should be just fine.
    Thanks so much anyway!!
    Dobrescu George likes this.
  14. lifeinabox
    The Ibasso is a great match.
  15. TheoS53
    Unfortunately it seems that that headfonics reviewer does not yet understand that it's the sensitivity/efficiency that matters more than the impedance (as well as whether it's a closed back, open back, or iem).
    The M0 can drive the Pinnacle P1 which is rated at 50-ohm and 96dB/mW (which equates to 109dB/V) in low gain. Your DT's 250-ohm and 102dB/mW converts to 108dB/V, so the M0 should be fine at driving it in high gain
