Shanling M0 - Nano size, touch screen, LDAC & aptX BT, USB DAC/transport and ESS Sabre ES9218P, FW 3.2
Discussion in 'Portable Source Gear' started by Shanling, Mar 16, 2018.
208 209 210 211 212 213 214 215 216 217
219 220 221 222 223 224 225 226 227 228
  1. csglinux
    Except that the iEMatch parallel and series resistors, in the process of reducing the effective z-out, also change the FR. That's what I mean by a little odd.
  2. Galeonero
    Hi, I'm asking you a question this dap I see that many are impressed with its sound quality and smallness. My question is I'm looking for something like this device but I do not know if it's so small, you who think there is an alternative for this price or a little more or better I adapt and do not put a case to get a little fatter? Thank you very much to those who answer me.
  3. Shanling
    I even have Hi-Res sticker on my passport. :wink:
    Yes, M0's internal DAC ES9218p converts DSD natively. INTERNAL transport, so the one between "chips" inside M0, is DoP, but then the DAC converts it as full DSD.
    Shanling Have any question about our players? Just PM me or send me email. Stay updated on Shanling at their sponsor page on Head-Fi.
  4. originalsnuffy
    quote from Shanling: Yes, M0's internal DAC ES9218p converts DSD natively. INTERNAL transport, so the one between "chips" inside M0, is DoP, but then the DAC converts it as full DSD.[/QUOTE]
    Shanling, thank you for clarifying this. This is what I had always thought, but some dialog on these forums seemed to imply otherwise.
    If you need some reviewers of the M5S.....I have plenty of experience with Shanling devices by now.....shamless plug
  5. endgame4
    I was refering to posts like 14482967 and 14494269 in this tread, both by @Shanling. Not all the other debate.
  6. fish1050
    I have a Hi IQ sticker on my passport. :)
    AndySocial likes this.
  7. P3108
    We are getting DSD native decoding but using DoP as the transport is what is throwing in the clicks. Either this is dealt with in software to correct the DoP by adding a leading silence I think (JRiver can do this) or as the chip is also DSD native capable as a transport then in theory the DoP could be rendered irrelevant. However, in practice this has issues apparently that must be greater than the clicks that DoP adds to the beginning of tracks.
  8. originalsnuffy
    It would seem that there are some fixes that can be put into place to remove the clicks. Perhaps after the M5S ships Shanling can address this with a new firmware update.
  9. vandubi
    I am a very happy user of the M0 but I am missing the possibility to transport to my mojo when in BT receiver mode.
    @Shanling
    Is there a timeframe when this feature will be implemented?
    :soon:?
  10. P3108
    Playing SACD ISOs is a temporary work around for a click free album listen in DSD (over DoP).
  11. MarkF786
    How does the M0 compare to the Radstone ES100 or Fiio BTR3 when used as a bluetooth amp?
    I'm currently using & enjoying the ES100, but I'm curious to try the M0.
  12. crabdog
    I tried it the other day with my Android phone and it works brilliantly. It sounds every bit as good as the other 2 plus you have the option of wired playback from the device itself.
  13. ChikiChpoki
    M0 and Radstone ES100 should sound different because of different DAC/amplification circuit. M0 has ESS ES9218P DAC chip, Radsone Earstudio ES100 has AK4375a (dual DAC scheme). Both DACs have their own integrated headphone amp on chip. But maybe there are more sophisticated implementation of amplification circuit on both devices, there are no detailed information. Same for Fiio BTR3 (AK4376a DAC). As for bluetooth receiver side there are difference in supported codecs. BTR3 have biggest codec support - SBC, AAC, aptX, aptX Low Latency, aptX HD, LDAC, and LHDC. ES100 supports SBC, AAC, aptX, aptX-HD and LDAC. By now M0 is limited (in receiver mode) to SBC, AAC and LDAC, but codecs may be added in future firmware updates. ES100 and BTR3 both have the same bluetooth chip - CSR 8675 Qualcomm chip. I can't find info on M0 bluetooth chip. Despite the above mentioned, there are may be HUGE difference of every day usage because of software, current firmware, button layout, etc.
    DBaldock9 likes this.
  14. radekhulan
    Can M0 be used as USB DAC (sound card) for Windows 10 PC, transmitting via LDAC to (Sony) headphones?
  15. RobinFood
    It can be used as a usb dac, but expect some semi-unusable delays for games and movies.
    In dac mode you can't use bluetooth though, touching the screen disconnrcts it as a usb dac.
    KamikazeGV likes this.
