- Aug 8, 2013
I don't think you understand the difference between general audio "balanced" and the way it gets used in the headphone realm.
Really, there shouldn't have to be a difference for anyone to understand. It should mean the same thing in the headphone realm as it means in the rest of the audio realm. Co-opting a term that has had a specific meaning for over a century and using it to mean something different makes the headphone realm look a bit backwaterish.
se
... right. electrically it makes no difference at all whether we talk about a front-end as i.e. a microphone or a turntable-pick-up (conducted in a balanced way to a balanced RIAA pre-amp), or in-between other audio equipment along the way, or a rear-end as a connection to a headphone.... the basic principles of "real balanced" always remain the same... Only if we talk about "active balanced ground" it would be a slightly different story then (...different concerning the way it works; the effect is still the sane...).
In my setup I found balanced connections most useful for MC pickups since their signals can be so very "weak", that a proper balanced connection on the way to the pre-amp was having a very positive effect.... also on the long way from pre-amp to my active loudspeakers I definitely prefer balanced.
But frankly, with those relatively strong headphone signals I wasn't really able to hear significant improvement between balanced or not, as long as both cables were of comparable quality (material copper or silver a.s.o.) and the amp's single ended output was on par with with the balanced output...
...and just to anticipate those "a balanced headphone cabling must always & necessarily be superior" advocates and protectionists... no, I am not deaf... yet...
