C_Lindbergh
They don't care, they still ignore the issue claiming its been fixed in a firmware update... It's unbelievable, just admit you ****ed up and offer a huge discount for owners of the Gen 1 once you release the Gen 2.
Sennheiser has never claimed that the power drain issue was fixed because they’re essentially saying it is by design. See their most recent comments in this forum.
I understand why people are peeved at the case-drain behavior but, to me, the tradeoff allowing instant-on and amazing sound quality is worth it.
- Is it optimal? No.
- Is it what most people are expecting? No.
- Is it a mistake? Yes and no; they designed it that way and have said so since the product debuted. It is in the documentation.
- Does the case-drain suck? Yes.
- Would I trade my MTW for any other true wireless currently on the market? Nope.
Yeah, it's by design. You know what would've been a better design choice? Not let the earphones stay on after putting them in the case. Have them turn off consistently when they're back in the case or just have a little button on the case that turns them on and off. That'd be a better design choice.
I don't get why this is so hard to comprehend. The MTW doesn't have a battery life issue. The issue is that they don't switch off after you put them away. When you use them normally, battery life isn't great but it's fine but if they keep draining and don't turn off after you put them away, then that's an issue that needs to be fixed.LOL. How do you know the Gen 2 will be good on battery?
how difficult can it be to change the firmware in order for the MTW to switch off when placed in the case???
Sennheiser tekkies wake up!
There always has to be a balance between battery life, driving power (amp) for sound quality, connection strength, and processing power (Bluetooth codec decoding, latency, and responsiveness). We also use NFMI to connect the two earbuds because it has advantages in transmission (not blocked by the body) and lower power consumption in our testing for the earpieces and the source device (like a smartphone) compared to multiple synced bluetooth connections.
Same. I deleted the app and redownloaded it.the new app update on my iPhone does not see them anymore.....seriously!!
