Jerrycan
- Apr 28, 2008
Hi,
Please try to insert the analog jack plug into your momentum wireless headset, and then remove it again.
There is a switch inside the jack of the headset, this switch turns off Bluetooth and put it into flightmode.
If this gets jammed by dirt, it might behave as you describe. Do the procedure with the jack plug severeal times.
Cheers
Flemming
Hi Flemming,
Just got my brand new momentum 2.0 and wireless stopped working after i've tried the jack one time. Thanks to your tip, got it working again! Thanks very much!
I noticed there's a sort of lock on the mini jack you must turn to insert (and remove) the plug properly. Not the most easy way, because the plug is very tiny, you've not much grip.
