Sennheiser IE80's Impressions Thread
post-15343120
Post #7,681 of 7,688
AltoBajo
UK
UK
It should be. What do you like the most about ie80S, and what would you want the upgrade to do? Depending on those answers, I could point to what is the most likely candidate for your upgrade
Well.it has been pointed out that the Xelento has more of everything that the ie80 and ie80S have,so that sounds great.With the ie80S,I really am listening to albums I've know for many years,and hearing previously hidden details,revelatory! My understanding is that the Xelento has a similar "romantic" and warm tone as the ie80 series,with extra detail without being sibilant or piercing in the treble region,important!.I have a pretty wide range of music files,Beatles,Stones,through to jazz,African,soundtracks,etc..Everything sounds great with the the ie80S,full,warm and detailed,with the same wide soundstage as it's predecessors.Do I need to upgrade?! Many years ago,I had vinyl systems,and each upgrade,eventually ending with a LinnSondek LP12,Naim Monoblocks,and Linn Isobariks rig,brought added and extra level of details.This is what the ie80S have brought to the table,more of everything.I will not be drawn down the upgraditus rabbit hole,plus my ears aren't so young! I do like DD iems.Would the Xelento be a worthwhile upgrade and end game iem for me? Certainly,the ie80S have shown to me what's possible,should I consider moving up a notch or two.
Many thanks for taking the time and trouble to consider my dilemma! It's very much appreciated!
post-15343203
Post #7,682 of 7,688
Mmurin
Paris
Paris
Well, I've owned IE80 and IE80s for many years, and owned and listened many other IEMs.
The only weak points of the IE80s for me are fit, noise isolation and flexibility.
If your fit is good the sound for me is unrivaled: bass detail, attack speed and subtleties of the mids are top notch and hold their ground against multi driver more expensive IEMs.
Concerning noise isolation it is below average, so if you listen to them in noisy environment you could probably do better.
Concerning the flexibility, their particular sound signature, which makes them suited for Jazz, Classical etc, also makes them unsuited for hard rock and metal, at least for me.
So to conclude:
- upgrade? for your music genres I doubt you will find better IEMs. The only noticeable upgrade would come from a good pair of speakers in a room with decent acoustics.
- better noise isolation? sony n3ap do better, but are inferior in bass detail and comfort
- listen to treble rich music like hard rock or metal? I would go with a different pair, not necessarily high budget (sony MH755 already do a good job for these genres).
Reactions: castleofargh
post-15344938
Post #7,683 of 7,688
AltoBajo
UK
UK
So to conclude:
I'm lucky because I get a perfect fit with the Senn. large foam tips,plus I have two Hybrid cables.It means everything is interchangeable between the 80 and the 80s.With a different model,I'd need to consider finding tips that fit,as well as aftermarket cables.At some point,I may well get a Sony DAP and go balanced,but that's just another Forza cable,simple.
I don't listen to hard rock or heavy metal,but they do sound great with Led Zepp,Kings of Leon,etc..In short,everything sounds great on them.Smooth,detailed,and I hesitate to say it,but truly analogue.Just like the good old days!
Anyone sitting on the fence about buying or moving up to the ie80s,really,do not hesitate.They're a big step up from the ie80,which were good anyway.I can only think that any negative reviews are from people who just didn't like their sound signature,haven't heard them properly driven,or didn't burn them in.I had mine playing for more than 100 hours before listening for the first time,and they've now settled in nicely.
May thanks for your input,it's very much appreciated.From time to time, we all need someone to tell us how lucky we truly are.All the best!
post-15344951
Post #7,684 of 7,688
Mmurin
Paris
Paris
100% agree. BTW I already moved a step up to 400 eur entry levels hifi speakers+amp, but rarely listen to them as they do not fit in my pocket! :wink:
post-15368931
Post #7,685 of 7,688
Mmurin
Paris
Paris
A message to invite you to request the new IE80s tested at https://www.rtings.com/
Attention to select the new IE80s and the old IE80
If we pile up votes maybe we will see it move up in the rankings of the preferred gear to be tested
post-15417547
Post #7,686 of 7,688
darkarn
Hi, I am an owner of a new set of IE80 and am beginning to read this thread for any useful info
So far here's what I have seen:
Hi, I am an owner of a new set of IE80 and am beginning to read this thread for any useful info, and then compiled all of these links from this thread (and some from my personal searches)
This post is for "basic"/"pre-purchase" knowledge
1. Changing of tips
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-90
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-102
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-139
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-160
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-161
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-162
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-169
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-179
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-189
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-205
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-208
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-212
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-227
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-233
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-234
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-244
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-249
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-260
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-261
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-263
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-270
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-272
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-273
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-277
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-278
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-281
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-283
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-307
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-314
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-316
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-322
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-325
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-347
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-356
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-362
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-377
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-382
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-389
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-415
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-425
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-431
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-433
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-434
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-441
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-442
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-445
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-446
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-447
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-448
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-463
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-464
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-471
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-473
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-474
https://www.sensaphonics.com/pages/audio-seal-test
https://www.headphonesty.com/2018/04/ultimate-guide-selecting-perfect-iem-ear-buds-tips/
https://aftersoundblog.wordpress.com/2017/06/08/eartips-reviewed/
1a. Custom Sleeves
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-336
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-375
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-379
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-386
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-387
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-390
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-417
2. Case
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-114
https://www.head-fi.org/threads/sennheiser-ie-80-s-impression-thread.859418/page-4
https://www.head-fi.org/threads/sennheiser-ie-80-s-impression-thread.859418/page-5
3. Bass Dial
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-401
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-403
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-404
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-407
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-460
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-470
4. Counterfeit Checking
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-157
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-360
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-365
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-385
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-427
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-428
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-438
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-462
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-506
5. Songs to Test With
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-168
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-275
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-304
5a. Check Stereo Balance With This (For checking seal e.t.c.)
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-344
6. Amp/DAC/DAP
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-171
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-295
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-349
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-408
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-409
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-420
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-421
7. Cables
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-173
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-174
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-178
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-190
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-191
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-211
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-250
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-296
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-330
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-351
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-368
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-378
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-395
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-406
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-436
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-457
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-461
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-480
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-481
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-483
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-488
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-493
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-497
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-505
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-507
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-508
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-510
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-512
https://www.head-fi.org/threads/sennheiser-ie-80-s-impression-thread.859418/page-6
7a. Stock Cable Issues with Cold Weather
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-341
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-342
8. Comparisons with Others
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-182
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-291
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-381
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-396
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-435
9. EQ
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-216
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-253
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-259
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-393
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-424
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-450
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-455
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-509
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-511
10. Wearing the IE80
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-338
11. Burn In
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-410
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-451
12. Exact Nature of the IE80 and FR Graphs
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-411
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-453
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-456
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-467
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-490
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-500
https://www.head-fi.org/threads/sennheiser-ie8-ie80-repair-spare-parts-replacement.803994/
13. Listening Volume Affecting the Potential of IE80
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-429
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-430
14. Moving On to IE80S
If anyone can help contribute by pointing out which pages are useful for what purpose, it will be much appreciated, thanks!
EDIT: Updated as of 0502/2020, at page 513 now
post-15434052
Post #7,687 of 7,688
darkarn
This post is for "advanced"/"post-purchase" knowledge
1 Breaking of Tip Nozzle and Repairing It
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-394
2. Tape Mod
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-209
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-213
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-217
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-218
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-219
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-220
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-222
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-223
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-225
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-229
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-246
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-248
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-265
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-269
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-282
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-286
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-299
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-300
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-301
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-313
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-397
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-398
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-399
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-419
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-449
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-459
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-466
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-489
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-498
https://www.head-fi.org/threads/ie8-ie80-mod-for-better-sound-v2-half-tape-mod-photo-added.760226/
3. Big + Small Tip Mod
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-317
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-318
4. Dealing with the Veil (i.e. Dual Flange + Tape Mod Configuaration)
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-412
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-414
5. Cleaning the Nozzles of IE80
https://www.head-fi.org/articles/how-to-clean-the-filters.13505/
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-437
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-439
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-440
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-458
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-475
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-479
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-491
6. Bass Leakage Tip Mod (a.k.a J444 mod)
https://www.head-fi.org/threads/sennheiser-ie8-impressions-thread.375547/page-536#post_11236833
7. IE8/IE80 Paper Napkin Mod
8. Using Tea Bags as Wax Guard Mod
https://www.head-fi.org/threads/sennheiser-ie80s-impressions-thread.569527/page-494
post-15453195
Post #7,688 of 7,688
darkarn
And I finally caught up to all pages! Hope these compiled links will help you as much as these did for me
I am going to test more before commenting on the IE80, but so far I can tell this solves a problem I didn't expect to have until I started using it in earnest
