Thanks for suggestion but it's not earphone for me:
No way I would buy product like that. Not only because of the price but it's very bad in my opinion on so many levels, friend has IE800. Cable is a disaster, cable noise is so bad they are to me useless outside, whenever cable touch my clothes/body i get hits inside my ears... Isolation is possibly even worse than IE8 / 80 and it's down the ear cable, not over the ear - which is not problem only because of extreme cable noise (cables are stiff also so noise is even more emphasized) but also problem because of fit, every now and then you need to adjust earphone inside ear, while over the ear cable design assure a lot more secure fit for a longer period of time.
Also I'm also 184 cm high (6 feet) and that silly cable lenght is so bad it barely reaches my pocket, so whenever I turn around earphones wanna fall out of my ears, let alone hold the cable under the shirt - then it's impossible to take out player/smartphone and change song without pulling earphones from your ear.
Overall IE800 is very huge disaster of an earphone in my honest opinion, while sound is good (bit too high treble imo but everything else is very good) physical aspects are so bad that it's completely useless product. My friend that got it was so frustrated he kept using his IE8 instead and IE800 only at home. I just can't believe how someone can live day to day with them and use them outside, more cable noise and earpiece adjusting inside ears then music. But everything has it's happy customers... Too bad because it really does sound good (better then IE80 imo)!
Thanks for suggestion! Thing is experience taught me that cable over the ear and comfort are first to come, also replaceable cables are great bonus (not because other sound better, but because it's the first thing that stops working with earphones in most cases). So physical requirements come first to me, over the ear design, replaceable cable is huge bonus, comfort, durability... because no matter how good it sounds if it's not convenient and comfortable, and if it will not be a good value (long lasting) it's not worth the trouble and money.
Still IE80 will do till I save up enough money for some top of the line earphone (even tho from what I've experienced it doesn't go much better than IE80, more different then better, depends on taste) or till I find some <500 $ upgrade if such exist...
