YamaVega
- Sep 18, 2014
Bassy sound and an enourmouse soundstage... are the IE80s the ultimate upgrade from the Pistons 2? Or are there much better high0end IEMs similar to the pistons?
I have not read through the thread. I just want to share what I know on Sennheiser.
First, they need a such a long time to arrive at its final result. I have cx 980, no much reputation at here. I believe few people have patient to wait it to arrive at its final state. Now I listened more than 1000 hours, and it's a total different earphones from the moment of open-box!! You cannot believe it! When I use nexus 7 with Neutron player to listen to classical music of flac or ape files, wow wow wow!!! Now I began my journal of Ie80. Now my ie80 is about 50 hours, no better than >1000 cx 980, but with more larger soundstage and 3D sound. But you can sense it have tremendous potential! (When I just got it, plug in, and my wife thought it's better than cx 980! But cx 980 also have great soundstage, totally out of head! If as someone share that Havi B3 are 10% larger soundstage than monoprice 8320, cx 980's soundstage should not be smaller than B3. After 1000 hours running, cx 980 have much better mid than at the beginning. Of course ie 80 have better mid. than 980)
Second, anyway, sennheiser's are tuned for classical, no matter 980 or 80, or 8. If you care mid. most, don't buy sennheiser.
Got to be worth a try. Plastic is notoriously difficult to glue though. Plastic is a "waxy" material. You could try superglue. I must admit the only thing that I usually manage to glue successfully is my fingers! Maybe Google glue for hard plastics.The right earphone area where you slide eartips over on my ie80s snapped..
Just wondering, has this happened to anyone? Any ideas? My warranty is up and I was thinking of just gluing it back together..
Hey guys, My ie8 cables aren't working properly in that sometimes one ear piece isn't playing music and the other is and visa versa. Do you think i should look for a replacement cable for it or just buy ie80s which are going for 280 on amazon right now. Thanks
Buying a new unit altogether seems like a drastic measure... Especially considering that Lunashops has a replacement cable for as little as US $8. Worth trying out before spending an additional 280 IMO.
