Sennheiser IE800 IEM's
Jun 23, 2020 at 9:54 AM Post #7,711 of 7,990
Hey guys! Im looking to buy a legit ie800 and i wondered what they sell for now used? Seen everything from 150 usd and up here on headfi!
Thanks!
Jun 23, 2020 at 10:39 AM Post #7,712 of 7,990
lots of fakes, hard to tell the difference, so buy from a respected buyer on head fi is the only way to go. dont buy used on amazon or ebay.
300 or under is a decent deal
Jun 23, 2020 at 11:00 AM Post #7,713 of 7,990
So there is no way to tell the authenticity by the looks of it? Im so tempted to buy one as they should sound pretty airy and open! Never tried one though.live far away from the cities and Norway isnt the easiest places to try headgear either. What about the QR codes?
Jun 23, 2020 at 11:38 AM Post #7,714 of 7,990
My pair of it is still on sale. I bought it here, from Mr. Kernel in november, last year. Kernel is an old head-fier. Please send me a PM if you were interested.
Jun 26, 2020 at 10:23 AM Post #7,716 of 7,990
Anyone know it its hard to fix the IE800 if the cable near/in the housings is getting weak? I csn see thaT AliE sells repair cable. Im going to buy a ie800, but i just want to know if it is easy to fix for myseld if thats suddenly will happen=)
Jun 26, 2020 at 10:37 AM Post #7,717 of 7,990
ive had 3 ie800s and use it over the ears, putting even more strain on the cable near the housing, and have never had a cable issue
Jun 26, 2020 at 11:20 AM Post #7,718 of 7,990
Thanks. Ive read that some said that numbers below/over a certain serial number is supposed to be better ? Is that true?
Jun 29, 2020 at 9:43 AM Post #7,719 of 7,990
Hi! Anyone knows where to buy good remote like RCS 800 from third party etc? That cable cost almost as much as i paid for the IE800😮
Jun 30, 2020 at 2:44 AM Post #7,720 of 7,990
Anyone know where to buy good tips for IE800? =)
Jun 30, 2020 at 5:18 PM Post #7,721 of 7,990
anyone?
Jun 30, 2020 at 5:49 PM Post #7,723 of 7,990
I got Comply tips for my IE800 from Amazon.
i read that i need special comply tips. does they have a special name? i will recieve my ie800 in a couple of days. but i want to order tips now to see what will fit me. what is the common one sto use? thanks
Jun 30, 2020 at 6:13 PM Post #7,724 of 7,990
I am currently using the silicone tips that come from sony mh755 as substitute. They fit very snugly. F38919B1-E3EF-484C-80C6-9B3AFABC1A68.jpeg
Jun 30, 2020 at 6:14 PM Post #7,725 of 7,990
The ones I use are Isolation Plus, with Waxguard to keep out debris, size small. If you're not sure about fitment, they do make sets with all sizes to try.
