Sennheiser IE8 losing sound in right channel
post-7372877
Thread Starter
Post #1 of 25
queuewindow
Like the title says, my IE8s are losing sound in the right channel. In fact, it's barely audible anymore. For logistical reasons I can't really send them to a workshop, so I'm checking to see if anyone's had this problem before. I have a feeling it might be a problem with the cable, but I can't be sure. Anyone?
post-7375193
Post #3 of 25
dura
Check out the jack; mine sometimes lost sound in a channel too, some fiddling and it came back, and there were more people complaining about; eventually I bought a new cable.
post-7375207
Post #4 of 25
queuewindow
Fiddling with the cable used to work, but not anymore. How would I go about replacing the cable?
post-7383807
Post #5 of 25
queuewindow
So, after some searching here and reading about people with a similar problem, it seems replacing the cable is the way to go. The thing is, I can't find a single store online that stocks IE8 replacement cables and ships internationally. Is it possible to get it directly from Sennheiser?
post-7384024
Post #6 of 25
aleki
you can get the cables from sennheiser; although if you're still within your two year warranty period, I'd see if they can replace it for free
post-7384041
Post #7 of 25
queuewindow
Taking advantage of the warranty period requires me to have registered my headphones with Sennheiser though doesn't it? I never did that when I got them
post-7384295
Post #8 of 25
aleki
nope, you just need your original receipt; but make sure its from an authorized dealer (IE: JR, Best Buy, amazon; not ebay, or a seller on amazon that sells items from their home)
If nothing else is wrong with your pair, see if they can just send you another cable, otherwise you may be without your headphones for quite some time
post-7384310
Post #9 of 25
queuewindow
I'm not sure exactly how to go about this seeing as I live in the UAE and had ordered my IE8s from Earphone Solutions. I don't recall them ever sending me a physical receipt either. What would you recommend I do aleki?
post-7384362
Post #10 of 25
aleki
Earphone Solutions should atleast be able to hook you up with your receipt; they should be able to look you up through adress or anything you gave them. I'm sure they keep records for several years.
As for Sennheiser, they have a location in Dubai. here's a link from their website. Give them a call and see what they can do for you. At the worst of it, you'll just have to buy another cable, although I've heard they are like $20 USD.
good luck mate.
post-7384448
Post #11 of 25
queuewindow
I've already called Sennheiser here, I was told they can't help me as they only service full sized headphones. Anyway, I'll contact Earphone Solutions and see what's up. Thanks for the help.
post-7384515
Post #12 of 25
davidhunternyc
This is not exactly true. You can go to the Sennheiser USA website and purchase the cable. There is a list with prices there.
post-7385487
Post #13 of 25
queuewindow
Are you talking about their parts and accessories store? They don't list the cable for the IE8 there, unless I'm missing something. It's why I was looking for other retailers
post-7385508
Post #14 of 25
davidhunternyc
Sorry, I just looked myself again and you are correct. I can't imagine that Sennheiser wouldn't help you with a cable, though, especially because it is detachable. What happened when you called them? If they say they can not help you, I would keep calling back and escalate the issue to someone else that is willing to help you. In terms of servicing full-sized headphones only, I sent my IE8's in for repair and they sent me new ones, albeit for $199. They should be able to send you the cable for free or for a reasonable price.
post-7385520
Post #15 of 25
queuewindow
david, I don't live in the US. When I said I called them I was referring to Sennheiser's Dubai office. I was told on the phone that they only service full-sized headphones but to bring mine in in case they can do something for them. It turns out they couldn't, and they offered to ship them overseas for maintenance but I'm not going to send them away for god knows how long when the fix is so simple.
