Sennheiser Headband help
post-14453507
Thread Starter
Post #1 of 4
HoneysPoohBear
Kentucky
Kentucky
Website
www.instagram.com
Does anyone know where I can find a replacement headband for my HD650s? Mine has a crack and plastic weld does not work. I don't care about color, I know the 580, 600, and 650s bands will work. Thanks for any help!
post-14454177
Post #2 of 4
Monsterzero
Down at Dinos Bar & Grill
post-14457085
Post #3 of 4
buke9
Help and Recommendation Contributor
Kentucky
Kentucky
Also check eBay as there are some cheap versions to be had there also don’t dismiss the wool covers as they are actually really comfortable.
post-14457198
Post #4 of 4
earphony
Vancouver
Vancouver
I get mine from AliExpress and I see no difference in quality for the low price. Though mine were for HD203/202s.
