Liu Junyuan
- May 22, 2014
My 2 cents on my recent audition of the HDV820 amp/dac. I have been getting the itch to upgrade my WA22 lately thanks to the HD800S.
My new reference is the He1 I heard a month ago. It is the best sound I have ever heard. The He1 is fast, natural, warm, detailed, dynamic... times a hundred. It literally disappears and you are left alone with the music. It's not a headphone system instead it's a teleportation device. It is that good. When I first heard the He1, I became confused. My initial reaction to hearing the He1 was utter disappointment. 'This sounds boring, let alone a $55,000 headphone'. Then Frank Sinatra came on and started singing the song 'Say it' and that's when I finally started listening. I left the store after listening to that song. My brain took at least a day to understand what had happened. I couldn't forget that sound. It finally dawned on me that the ultimate fidelity in Audio would be to having all the gear disappear. Just you and music left alone.
Getting the HD800S closer to that sound signature for me is the ultimate goal. Even if I get to 80% of that sound, I consider it a massive success. I honestly think the HDV820 has the capability of achieving this goal.
A summary of my current system. I have had the WA22 for almost three years. In that time, I have upgraded the valves, the capacitors and the resistors (the ones in the signal path). The source is a MacBook playing FLAC files playing through Audirvana upsampled to 256DSD and then fed to the Holo Spring DAC lvl 3 via a SU-1 transport. The signal stays balanced from the DAC to my ears. I listen to a variety of music; classic rock, female vocals, Jazz to a little bit of symphony orchestra. The last two absolutely shine on the HD800S.
So I decided to take some Dave Brubeck and Dvorak Symphony stuff to audition the HDV820. I spent a good hour listening to the HDV820. The HDV820 was connected via USB to the PC. The Flac files were played via Winamp (more about this setup later on). The following notes are my impressions.
Bass: Better on the HDV820. More prominent with a tiny bit more punch and maybe a little more detailed. If I was to give the HDV820 a 9/10 on the scale for bass, the WA22 is 8/10.
Mids: The WA22 has a little more midrange emphasis. We are talking about a heavily modded WA22 with valves that are known to make it sound closer to a Solid State amp. The difference was subtle. The standard WA22 has a more gooey, warm or lush kinda sound. I am not a fan of this. The HDV820 has beautiful mids, with the right amount of smoothness/warmth. The clarity of the HDV820 along with it's general presentation really make it sound like you are listening to a baby He1. The WA22 does exhibit a little sibilance on some tracks. The tracks I used to evaluate the HDV820 didn't have vocals so couldn't compare the two. I would give them both a 9/10. Could be a DAC issue perhaps?
Treble: Both extended wonderfully without any harshness. Again both deserve a 9/10.
Clarity: The HDV820 clearly wins. But I am comparing a Solid State amp to a Valve amp here. The WA22 had a tiny bit of distortion in comparison. 9 for the HDV820 and 8 for WA22.
Soundstage & imaging: Both were on par. More impressive with the HDV820 being a solid state and able to match a tube amp that's known to present a big soundstage. 9/10 for both.
Details: HDV820 would get the nod.
Speed: HDV820 is not fast or either slow. This is where the He1 was clearly better. The transients are amazingly fast on the He1 and so they should be considering it is an electrostatic setup. I was more impressed with WA22 not lagging too far behind the HDV820.
Back to the setup of the HDV820. I honestly think if I was playing upsampled DSD files into the Holo DAC and then feeding it to the HDV820, this thing would go up another level. A very good DAC/source into the HDV820 is what is required to get to that 80% margin.
I left the shop with a smile on my face. Not because I had found my next amp but because Sennheiser is definitely going in the right direction with the HD800S and the HDV820. My next audition will be the Apex Teton. Unfortunately, this is a tough ask as I don't know of any owners in New Zealand. But if I was asked for a amp recommendation for the HD800S, the HDV820 would be my first choice.
I would have a look at the DNA Stellaris if you're serious about absolutely maximizing the HD800S.
