- Jan 30, 2011
Thanks for that - another graph which shows the greater treble extension on the HD800S - which is what we were discussing
That shriek(shrill, sharpness) is still not fixed even with whatever the modification they are claiming. So much BS.Here's the HD800 vs HD650, and we already know that the modifications to the HD800S centered around lowering the 6 kHz spike and increasing the mid-bass response
One of the reasons I specifically got the S version (instead of HD800 plain) is because I like it with solid state amps even the cheaper ones.That shriek(shrill, sharpness) is still not fixed even with whatever the modification they are claiming. So much BS.
Tube it guys. LOL.
Where do you see that in that graph by Sonarwoks? The blue lines of the HD 800 S are dropping faster (around 12k) than the HD 650.
It almost looks like the HD 800 S builds up to 1 big peak and then rolls off.
I normally don’t refer to measurements much, but those measurements agree to what I hear in the upper treble regions.
Utopia starts to drop even earlier - around 10 kHz. It just has some additional resonance peaks later on, to make up for it
P.S. Also, if you can believe those measurements (I'm a little cautious of measurements much beyond 10 kHz), the HD800S only has less treble than the HD650 once you get past about 18 or 19 kHz.
