Sennheiser HD660S... Finally a successor for the HD650?
Nov 8, 2017 at 3:37 PM Post #961 of 8,970
swmtnbiker
Previously known as dpippel
Yoyodyne Propulsion Systems
Yeah, I'm not sure how well-regarded, traditional HD 650 OTL tube amps like the Bottlehead Crack will pair with the 660S at half the impedance. A powerful SS amp will be fine though. The 660S sounds fantastic balanced out of my HA-1.
Nov 8, 2017 at 3:54 PM Post #962 of 8,970
Hifivoice
Just got my HD660, order to delivery time was 1.5 days :)
A few hours ago, I was still "married" to my HD650. No other headphone could ever please me more than the HD650. Most headphones are very problematic in the treble area (too sibilant, splashy, a constant zizz etc.), and miss the richness of the HD650 treble. On the HD650, the different cymbals of a drum kit do sound different, and expose the tonal differences in their decay. On top, a lot of headphones miss sufficient energy in the fundament area (chest, instrumental cabinets), either bass heavy (thick), or lots of mid (tonal rich), but most expression and push in the sort of music I like comes from the fundament area (voice, piano, guitar), so this is an important aspect for me. Headphones like the HD800/700, Philips Fidelio (close though), AKG 7xx, Beyer Dynamic 8xx/9xx all don't work for me for that reason.
So why an HD660 then? Yes, there is definitely some "muddiness" in the HD650 sound, the fundament region (chests, cabinets) does melt with the harmonics further up in the frequency regions and masks details. It does sound very rich, but in busy rock music it can start to sound "stuck", loosing the liveliness of the performance. Furthermore, the top end does sound a bit recessed (rich but not sharp), and the bottom end of the bass is rolling instead of punching. Not to the extend that it is disturbing, overall I think the trade-offs are still very good compared to other headphones. The HD600 sounds a bit more "sharp" and less "wooly", but I was always disturbed by its edgy treble, that makes different cymbals sound more alike (exaggeration makes my point clear, in case an HD600 admirer feels a bit upset :wink: - the HD600 is a nice pair of headphones, but not very refined in that region in my opinion, it is treble in quantity and not quality, and it lacks in the fundament region in my opinion).
So I took the risk to order an HD660, knowing that when ordering it via the web I have a 2 weeks guarantee to send it back for full refund according to the protective laws in our continent. No need to do so! The HD660 is wonderful!
First of all, it has a somewhat different timbre. Less "warm", but certainly not analytical, and also "less hollow". In the beginning I thought it was a bit "thinner", but this is not the case. There is less melting of bass/fundament/mid-range. The bass is there, the fundament is there, the midrange is there, but more independent, and better harmonically structured. For instance, when listening to a Viola Concerto of Brahms (Zimmermann and Gernstein, label Myrios Classics) you can hear the different elements of the piano much better, what is the snare, what is the cabinet, what is the reverberation, the panel resonances, etc.
This brings me to the second point, the spatial projection is a bit bigger, not because it creates an artificial large space putting everything more distant, but you can better distinguish the direct sound from the reverberant sound of the players in the recording place. This adds to the quality of sizing instruments better, on the HD650 there was the tendency that instruments projected more to the same size (again, exaggeration makes my point clear, on the HD650 it wasn't bad, on the HD660 it is better). It also adds to a better projection of "silence", the decay and dying of tones is "more explicit" and "more positioned", as if there is a lower noise floor. Also side-sounds (fingers moving guitar snares creating scratchings sounds, musicians turning sheet papers of the scores) is explicitly there now, it draws your attention (but doesn't distract, it is not magnified, it sounds natural).
Bass is tighter, but also a bit less (in the 80-150Hz region). There is plenty and enough, the HD660 reveals the deeper bass better, not in magnitude, but because it is not masked. When listening to it a couple of hours, and going back to the HD650, the HD650 sounds "coloured" in that region, as if you listen to a speaker with cabinet resonances/reflections, where the HD660 sounds as if there are hardly any resonances. That might be confused for "thin", I perceive it as "more correct".
Then, the treble is a big plus of the HD660. It is "sharper", so there is a lot more fun with cymbals et.al. in the higher treble regions, but without the famous "treble becomes fatiguing" problem (it even passed the "Innocence Mission" test with the over-harmonized song 'When Mac was swimming' from the album 'Befriended'). It has the same type of richness that you also hear from high end speakers (with properly filtered diamond, ceramic or beryllium cones), where you suddenly hear drum kits consist of many different cymbals, and brass can sound very different under different angles and play styles. Female voices have more "sigh", more "ph", and "moving lips". I can put the HD660 much louder on pop/rock records than the HD650, that start to melt the fundament/mid, and the lower treble becomes somewhat pressing on the ears. Therefore the HD660 gives a more dynamic appeal. This is very clear on drum beats, more instant, and with more kettle sound. It is not a head-banger headphone or a punch-the-bass-on-the-eardrums experience (luckily not). But Radiohead, Rush, Michael Jackson, Fleet Foxes, Diana Krall, etc. etc. all sound perfectly fine, and can be played loud without tonal stress. The micro-contrast as heard on authentic instruments in for instance string quartets give a tremendous rich sound with a lot of micro-contrast.
Overall, the HD660 sounds less "romantic" than the HD650, and I think it sounds more honest, with a richer tonal structure over the full frequency range instead of only in the fundament/mid range. It brings a lot more excitement by exposing the subtle tonal expressions musicians add to their interpretations. A high music-is-fun factor. Cool, I'm happy if that wasn't already obvious.
Is it worth the money for an upgrade? My initial impression is it definitely is. It is not a completely different animal than the HD650, it still sounds as a HD6xx product, but it improves the weaker points of an HD650 significantly, and brings no new weak points in return. Only if you like the bold sound in the upper-bass/fundament of the HD650 you may miss that a bit. But it is not only worth the investment because of those improvements, but also because it brings the HD6xx sound to my mobile equipment. I usually listen on my computer via an iFi Micro iDSD (worth every penny for driving an HD650), but my (EU volume capped...) iPhone is able to drive the HD660 to sufficient levels with the same fun factor.
All my opinion and trade-offs of course.
Nov 8, 2017 at 4:23 PM Post #963 of 8,970
qrtas
Atlanta, Georgia
Very well written. Thanks so much for sharing your thoughts.
Nov 8, 2017 at 4:28 PM Post #964 of 8,970
Rob80b
Toronto, Ontario
Just got my HD660........
Thanks for the insights...
Tonally... from the reports so far…seems the 660s "are" sounding more like the 700s (which I preferred over my 580/600s) …. minus the sound staging capabilities (no angled drivers) and the so called peak (which I never noticed).
The 650s while enjoyable are still more often than not too forgiving for my preferences, a more precise (clearer) rendering is always welcome in my books, so if the 660s add a touch from the 700s while somehow maintaining the 650s character they may be indeed be a winner and my next work horse. : )
Nov 8, 2017 at 4:55 PM Post #965 of 8,970
pietcux
Freiburg im Breisgau, Germany
Thanks for putting my experience into words. I had to unbox the HD660S instantly after reading your post. Diana Krall "Glad Rag Doll" is running from my DAP now... I had this combo on 5 hours straight at work today with different genres. Can hardly take them off.
Nov 8, 2017 at 7:09 PM Post #968 of 8,970
DoctaCosmos
So I’ve heard a lot of comparison of abilities of each of the line. As far as music preference would it be correct to say 600/classical, 650/vocal,acoustic 660/live,rock?
Nov 8, 2017 at 7:55 PM Post #969 of 8,970
god-bluff
God's own county
IMO everything sounds great from my HD600s. I don't actually think classical, as good as they are, is their strongest suite. For instance the various Beyers I've had are just a little bit better for that genre due to their greater soundstage and perceived detail (due to their extra brightness?).
The HD600's are superb with classic and progressive rock, acoustic and Jazz. (edit.. particularly anything with real instruments) Great with anything you throw at 'em really. You hear what's on the recording little missing and nothing exaggerated....Natural
Nov 8, 2017 at 8:55 PM Post #970 of 8,970
Tuneslover
SW Ontario, Canada
I actually always felt the soundstage of the HD600, and the HD650 to a lesser degree are slightly too small and closed in, similar to the Focal Utopia...(HD650's soundstage may actually even be bigger than the Utopia).
It would actually be a welcome change to me if it was alittle bigger/wider on the HD660s.
Just my 2 cents.
I have the HD650 and also the HD598SE. The soundstage of the HD598SE is way wider than the HD650. Where does the HD660S soundstage fit amongst these 2 headphones?
Nov 8, 2017 at 8:56 PM Post #971 of 8,970
Pedro Oliveira
Yap. The more i read i feel the same too. So in a way the hd660s makes sense in the line since the hd600 represents neutrality, the hd650 smooth, warm and laidback and the hd660s represent the more agressive aproach for those who like this type of sound but want a more lively experience. All share the same sound basis but theres a bit of variation for everyone now.
The only weird part is that this kind of makes the hd700 obsolete but i am pretty sure the hd7xx line will be updated soon. It has to be or otherwise it just not make sense.
Nov 8, 2017 at 10:45 PM Post #973 of 8,970
Hondadude85
Phoenix, AZ
I should sue you. You’ve just made me, by twisting my arm, spend $500 on another pair of headphones. I’m a die hard beyer fan but I have always loved the HD600/650 - but my issues with them have always kept me selling them shortly after I got them. It sounds like the 660S fixes all of them. And the fact that they sound good out of an iOS device?! Heaven.
Nov 8, 2017 at 11:51 PM Post #974 of 8,970
DavidA
Hawaii
If the HD660S shares some of the traits of the HD600 and HD650 its still pretty different sound from the HD700 since to me my HD700 is quite a bit different from my HD650 and previously owned HD600. The only short coming of the HD700 to me are the recessed mids, other than this it sounds better to me than both the HD600 and HD650 and is also slightly easier to drive since I can use a old Fiio X3 DAP to drive them while the HD600/HD650 take a decent desktop system to get them to sound decent IMO.
