Aren't the 650 and 600 pads interchangeable?
They are the same for 600 and 650, yes.
Does anyone actually have proof the HD660S pads are different?
Yes indeedI was trying to genlty say to Jude "You can do the Hd600 measurements putting the HD650 pads on the HD600 without waiting for the new pads"
Shipped, should be arriving Wednesday.
I have both the HD650 and the HD660S. Yes the pads are different. The HD660S's pads are deeper. I measure 2.7 cm against 2.2 cmThey are the same for 600 and 650, yes.
Are the plastic earcups deeper? I'm asking because the earpads seem identical exterior size from the pictures. Maybe the drivers are placed farther from the ears. Also, beware of old pads, especially if you didn't de-clamped your pair and more than 6 months have passed. My first pads of the HD650 lasted me 6-7 months (they were flatter than a pankake), then I bent the metal headbands and the next ones looked the same for 2 years.I have both the HD650 and the HD660S. Yes the pads are different. The HD660S's pads are deeper. I measure 2.7 cm against 2.2 cm
The HD650 is 3 years old, the pads are compressed, I measured the least compressed area.How old are the pads on the 650's? They will compress with use. Also where did you order your 660's from?Am interested in these to go along with my 800's. Thank you
My HD650 is bent since the beginning. It is my second pair. The rest of the can is identical parts. The changed the paint to no paint, they took the HD700 drivers and deeper pads with the same surface material. That's all.Are the plastic earcups deeper? I'm asking because the earpads seem identical exterior size from the pictures. Maybe the drivers are placed farther from the ears. Also, beware of old pads, especially if you didn't de-clamped your pair and more than 6 months have passed. My first pads of the HD650 lasted me 6-7 months (they were flatter than a pankake), then I bent the metal headbands and the next ones looked the same for 2 years.
PS: Now that I've seen connieflyer's question (I was wrinting at the same time he was) and your answer, it seems that the earpads are the same depth, if you take the compression into account.
Sorry if I ask, but can you say where you've ordered them, I'm not able to find a place that ships to Italy![]()
Thanks for the info. 0.5 cm is quite a bit more indeed.I have both the HD650 and the HD660S. Yes the pads are different. The HD660S's pads are deeper. I measure 2.7 cm against 2.2 cm
Straight from Sennheiser but you can only order them if they are available in your country from their store as you can’t chnage the shipping country.
Have you checked Sennheiser Italy yet? If not you would have to wait a bit or I can order them for you here and ship them to you if you want them fast.
Sometimes looking for the product, researching the product and building up an excitement in oneself at the thought of having the product can be more rewarding than actually owning the product.
