Sennheiser HD650 & Massdrop HD6XX Impressions Thread
Mar 3, 2013 at 6:58 PM Post #11,131 of 46,838
You can get a decent soldering station from RadioShack for under $40, and definitely get some silver solder. That will make the job much easier.
Mar 3, 2013 at 7:13 PM Post #11,132 of 46,838
If anyone wants a pair of great condition HD650s, or knows anyone who's looking...
http://www.head-fi.org/t/653829/hd650s-like-new-condition
I want some K702 65th Anniversaries. They are so sexy. And I literally never listen to my HD650s anymore.
Mar 3, 2013 at 11:48 PM Post #11,133 of 46,838
I recently went crazy in a moment of weakness ( i am NOT a cable guy) and bought some Moon Audio Black Dragon V2 for my HD 650's.  I've had them for 3 years now and I had run over the stock cable with my computer chair a couple of times.
    A new cable was in order.   I must say the Moon cable has given the 650, to my ears a shot in the arm.   The senns just sound stronger and fuller now and my Lyr's volume control is down a couple of notches!   10 o'clock instead of 11:30.  Improved efficiency maybe?  Don't have the technical tongue to explain the improvement but it's definitely there.  Maybe some one here can elaborate?   The 650's are the same only more so.
   I have no affiliation will Moon Audio except as a customer I might ad.   Lets just say I 'appreciate' my 650's more with the new cable.    Did I just say that?  Time for some breakfast.
Well I was skeptical at first, but reading around it really seemed like the HD 650s seemed to benefit more from cables than other HPs... So i decided to pick up a used black dragon V1 for cheap (full retail for most of them is ludicrous IMO).  And in all honesty... I heard the same things you did... still same sound overall... but just cleaned up and more on the ends (more punchy bass, slightly more energetic trebles).  My stock cable was brand new basically... so not really due to wear and tear.  Did some testing with my friend (also an engineer who was a cable skeptic) and even he couldn't deny there was a discernible difference.  Just my own experience... YMMV
In the end... are expensive aftermarket cables worth it?  Prob not for full retail... most ppl are better off saving for better amp or new HPs.  But if anyone's feeling open minded and can nab a cheap cable to test out and try it... I'd recommend giving it a listen.
Mar 4, 2013 at 5:37 AM Post #11,134 of 46,838
Hi guys,
I am going to get good amp for HD650 and was pretty much decided to get Schiit Lyr. Today I found in amp sale section Woo Audio WA6 for decent price. Is it good amp for HD650 or Lyr is better ?
Thanks for opinions.
Mar 4, 2013 at 6:32 AM Post #11,135 of 46,838
Hi guys,
WA6 all the way! For me, I found the sound of the Lyr to be a little brighter but also harsher and more sibilant. Frankly, it sounded cheap. I preferred the sound of the Asgard/Valhalla. Bearing in mind the Lyr was designed with power in mind to drive more demanding orthos. The Woo has a much more refined and smoother sound. It's a lot more euphonic and musical. The pairing with the HD 650 is a dream. Lush and romantic. If you play around with tubes you can also tailor it to sound a lot more to your liking but even with stock tubes it really does sound great.
This may sound silly, but you should really endeavour to find a place where you can demo these amps yourself. Everybody ears are different and it's best to pick your own personal preference. BUT SERIOUSLY, pick the Woo. ;)
Mar 4, 2013 at 7:14 AM Post #11,136 of 46,838
Thanks for information. Just wanted to ask... I have Magni and Modi now, do you think it is really dramatic change to WA6 and Modi ?
Tbh I hated HD650 from FiiO E11, when I got Magni and Modi.. it was big change and I started to like them so that's why I'am looking for even better amp now ;)
Mar 4, 2013 at 7:37 AM Post #11,137 of 46,838
The FiiO E11 doesn't have the capability to properly power the 650s. It would be holding them back. However, the Magni is capable of driving the 650s reasonably well. By upgrading to the WA6, you are firstly guaranteeing that you will get the most out of your 650s. But mostly, you are introducing a level of tonal improvement that is a step above. I would say you wont notice as much of a drastic jump as you did from E11 to Magni as for as the power capabilities. Where the real improvement you'll notice is the increased soundstage, the better instrument separation and increased detail. Furthermore, you'll notice an increased musicality that really complements the natural warmth and euphonic notes of the 650s. Hope that helps! :)
Mar 4, 2013 at 7:43 AM Post #11,138 of 46,838
Do these ever "open" up and sound better?
The sound seems like its coming through foam.....and its really starting to bug.
I guess because Im a huge grad0/alessandro fan.....maybe these and the other headphones I own the DT-250's are not for me?
Mar 4, 2013 at 7:58 AM Post #11,139 of 46,838
The 650s do open up a bit, but not much. I suspect its because you are a Grado fan, the smoother, laid-back, midcentric warm sound of the 650s are just not as favourable to your ears. :)
Mar 4, 2013 at 1:59 PM Post #11,141 of 46,838
Take the Pads off than remove the foam grill from in front of the drivers,makes a big difference,save the foam in case you dont like the sound so you can put it back.
Mar 4, 2013 at 2:14 PM Post #11,142 of 46,838
Do you have them well amped and with a good DAC?
Of course they'll never sound like a Grado, but mine are crystal clear.
Mar 4, 2013 at 4:04 PM Post #11,143 of 46,838
I agree too. I was a really huge skeptic in terms of cables but I did find a fair offer for  a used equinox cable. I know all the cable talk is very controversial and highly subjective but unfortunately for me (more unfortunate for my wallet), there was a prominent change. The cleaner sound definitely changed my mind quite a bit on how HD650's handles EDM. Are these cables worth the $300+ price tag? That is up to each individual person. To me however, I think that is far too much of an asking price even if the changes were quite significant. If people can find these cables for a more affordable price however, I do see these as being something worth trying out. Otherwise save up or use the $300+ to go towards a great AMP or DAC.
Mar 5, 2013 at 3:19 AM Post #11,144 of 46,838
I think removing the foam totally ruins the sound. Fine they may sound brighter but that warm seductive midrange is then totally gone - you may as well not have a 650! However I'm buying some new cables soon.
