I really like this chart! Very informative - thanks for sharing.I learned on this(range at the bottom):
I don't know if that chart should be a reference. It's been mine for a long time, so if I talk about midrange, you can be confident that I'm referring to this. ^_^
About flat midrange, I'm sorry to tell you that with headphones, there is not much that applies to all listeners. A graph a dummy head measures is based on some averaging of human heads. But beside a bunch of guys falling right on that average body, everybody else will be a little different and a measurement at their eardrum(if it was possible while alive and not screaming from pain...), would show a different frequency response.
For example, Harman came up with a headphone target(very serious work) that seems to please a majority of listeners. So it's probably a good idea to start with something similar to that target. But a majority in this case is somewhere around 60%. Leaving about 4 out of 10 listeners wanting for something different!!!!
That doesn't help you at all, sorry. But hopefully it can help you avoid a few bandwagon traps later on. Beside trying to see if you get lucky with some standards, your best bet is to try a bunch of headphones with known FR, and learn to correlate how you feel with those graphs so you can determine where to go next. Or to play around with an EQ, also to learn more about your very own needs. I hate it, but some serious amount of luck is involved in finding our neutral or our preferred sound(often enough the same thing).
Sennheiser HD650 & Massdrop HD6XX Impressions Thread
- Thread starter tangsta
AxeMadman81
When i listen To the music,my focus Is on the Electric Guitar..I listen To Rory Gallagher,Jimi Hendrix,Ritchie Blackmore,Gary Rossington,Uli Roth ecc...Guitar Is Basically in the Midrange region of a Mix with Vocals (I Don't care Vocals).It's important to me that HD600 response Between 1500/4000 kz Is Flat or 1/2/3 db UP..I really like this chart! Very informative - thanks for sharing.
So I've owned my 650 for 4 months now and used them as my daily driver for 2 months or so. I've since tried a lot more headphones and wanted to talk about something I don't often hear when people discuss the hd650. This isn't a warning, it's just something to keep in mind, as it can be both amazing and too much of a good thing. The mids are very, very smooth. Veeeeery smooth. When I listen to let's say some metal and try to listen to what's happening on the guitars I find myself struggling because I feel like there isn't enough detail, and it's so laid back that it doesn't feel concrete enough, if that makes sense.
I've been going back and forth on if I want to keep my 650 or 580 and right now I'm leaning towards the 580 simply because of 3 issues with the 650: The bass is messy, and there's no way to fix it with eq, it's just how it is. The mids are extremely smooth (to a fault for me) and despite me trying I struggle to lift the veil in the treble area. When I bought the 650 my thinking was that the bass is good enough, treble are good enough, but the mids are *amazing*. After having tried more options I feel like both the treble and the bass are dissapointing, and the mids are sometimes good and sometimes not. Also, after comparing the 650 to the 580 I find that the 650 timbre is quite off. I know it's kind of a big selling point, but the timbre honestly is too warm to sound truly natural to my ears, at least.
That being said, these are subjective "issues". The 650 (and esp 6xx if you live in NA) are GREAT deals, but I find people simp for them to an unhealthy degree. They're exceptional because they don't do anything horribly long (unlike other offerings in the midfi price range) but the things I mentioned above are things I can't ignore, and it makes me a bit sad. If I had enough money to have 4-5 pairs of headphones I'd keep them, but I'm looking to own a max of 3, and with the Bori and 580 that means I have one more slot, and it's no longer reserved for the 650 for
TL;DR: 650 are obviously amazing, but they're not without their faults, which needs to be kept in mind when buying them.
megabigeye
I agree with you about guitars— on the HD 650 electric guitar distortion just sounds a little too nice. Like a guitarist might want to be a cool badass in a leather jacket, cigarette dangling from the corner of his mouth. But the HD 650 says nope, you’re a gentleman with a soft cardigan. Maybe you can have a pipe, if you behave.So I've owned my 650 for 4 months now and used them as my daily driver for 2 months or so. I've since tried a lot more headphones and wanted to talk about something I don't often hear when people discuss the hd650. This isn't a warning, it's just something to keep in mind, as it can be both amazing and too much of a good thing. The mids are very, very smooth. Veeeeery smooth. When I listen to let's say some metal and try to listen to what's happening on the guitars I find myself struggling because I feel like there isn't enough detail, and it's so laid back that it doesn't feel concrete enough, if that makes sense.
BabetakCZE
Are the HD 650 and 600 again Made in Ireland or still Made in Romania?
I just noticed that on Sennheiser site they now state this:
Or maybe they mean that only the transducer is Made in Ireland?Everything about the HD 650 was made with more in mind: more details discovered, more musicality, and definitely more time for monitoring. Made in Ireland at a state-of-the-art production facility, the HD 650 combines the best of modern transducer manufacturing with the attention to detail required to handle a wide variety of acoustic materials.
The HD 600 is assembled in Ireland at a state-of-the-art production facility with the attention to detail required to handle a wide variety of acoustic materials.
Deceneu808
If i recall correctly, the drivers are still made in Ireland, shipped to Romania and then the headphone is completed here
Correct, and aside from a less-than-six month blip as the Romanian assembly line scaled up, there's no quality difference.If i recall correctly, the drivers are still made in Ireland, shipped to Romania and then the headphone is completed here
WaveTheory
Hi, all. I've been doing written reviews of gear on HiFi Guides Forum and Head-Fi for over a year now and have now launched a YouTube channel. I did a 6xx review as a baseline establishing review for the YT audience. Please check it out:
equalspeace
- Aug 12, 2016
The 600 will give you your well etched guitars for sureSo I've owned my 650 for 4 months now and used them as my daily driver for 2 months or so. I've since tried a lot more headphones and wanted to talk about something I don't often hear when people discuss the hd650. This isn't a warning, it's just something to keep in mind, as it can be both amazing and too much of a good thing. The mids are very, very smooth. Veeeeery smooth. When I listen to let's say some metal and try to listen to what's happening on the guitars I find myself struggling because I feel like there isn't enough detail, and it's so laid back that it doesn't feel concrete enough, if that makes sense.
Too much for me - I had both the HD 600 and 650 and sold my 600.The 600 will give you your well etched guitars for sure
AxeMadman81
Why You do That? Electric Guitar Is not good with HD600?Too much for me - I had both the HD 600 and 650 and sold my 600.
CAJames
Not enough bass for me with the 600. JMO of course.Why You do That? Electric Guitar Is not good with HD600?
AxeMadman81
From 60 to 120 the response Is Not Flat but Underemphasized of 5db
This could be a problem..No bass detail in That Range..
Fortunayely,From 120 to 250 hz Is Basically Flat
I prefer the more laid-back treble of the HD 650.Why You do That? Electric Guitar Is not good with HD600?
AxeMadman81
What do you mean with Laid back Treble?I prefer the more laid-back treble of the HD 650.
Total: 7 (members: 0, guests: 7)
