CanadianMaestro
down the wabbit hole, this thread.
I just had a look at B&H and the HD 650is not discontinued.
I have a question about the clamp in HD 600 and 650, since I hear they've got a whole lot of clamping force. Can you declamp, and I mean declamp the heck out of them without breaking anything?
Give it one week you won't even notice it.
Depends on the person, for me the HD650 and HD600 brand new gave me a headache after a few minutes, and you can gently bend the metal sliders to reduce the clamp if its really needed but don't over do it since it needs some force to create a good seal.
Thanks. Seems it is a problem after all. I have trouble when there's clamping with headphones and eyeglasses, so it's probably prudent to stay away. I'll pay more and get the SRH1840 then, it seems to be a champ when it comes to clamping comfort (I love how nicely it stretches).
I found clamping on the X1s so bad I needed to stretch them so much they would sometimes fall off my head. It's those stupidly rigid stainless steel bands. After the stretch they weren't uncomfortable, but headphones being loose on your head isn't a good thing. Perhaps my head is made of glass, which I guess is odd considering the 65cm hat size.
The style of the frame of the glasses (one pair is snug to the side of my head and quite comfortable with most of my headphones while an older pair (more stylish) as a gap and is not as comfortable) makes a big difference on how comfortable the headphones feel and it also impacts the sound depending on the headphones. I ware glasses some times and the HD650 is okay for me after bending the slider a touch by the SRH-1840 is a bit better comfort wise to me.
